pcmforless
Old 01-29-2012, 01:18 PM
97badass's Avatar
Default pcmforless
I've got an ecm here with a pcmforless sticker on it, how do i find out what tune is on it?
Old 01-29-2012, 02:04 PM
Lextech's Avatar
Read it and look at the calibration info. Then find a stock tune with the same calibration info and use the compare feature of the software to see the differences.
Jeff
Old 01-29-2012, 02:08 PM
edcmat-l1's Avatar
Call PCM4less?
Old 01-29-2012, 02:17 PM
97badass's Avatar
ed im glad you responded... the ecm i have is a 4398? what would it have came out of?
Old 01-29-2012, 03:59 PM
97badass's Avatar
wrong number, its a 610 ecm which from my research says its from a truck? but it was flashed to an 02 ws6... so would that have the 0411 os?
Old 01-29-2012, 04:51 PM
Lextech's Avatar
A 2002 WS6 has a 12212156 Operating System flashed into a 12200411 PCM.
Old 01-29-2012, 05:02 PM
97badass's Avatar
well in that case, what ecm do i have? i have been racking my brain trying to figure it out...
Old 01-29-2012, 05:17 PM
Lextech's Avatar
The LS1b 512kb PCMs are interchangeable with the proper operating system flashed into them. If it is a 610 PCM and has had a "Full Flash" flashed into it from a 2002 WS6. Then it should read out as a 12200411 PCM with a 12212156 Operating system. If you wanted a 2002 WS6 tune, then you should be good to go.
Jeff
Old 01-29-2012, 05:32 PM
97badass's Avatar
yeah im messing with my wiring harness and converting it to work with the 411 pcm. and make all this stuff work in my 95 controlling the lq4
