Need help with front driverside wheel, too much camber =/
Old 03-18-2004, 04:28 PM
Monello's Avatar
Default Need help with front driverside wheel, too much camber =/
Hey guys, trying to figure this out, some of u guys remember the run in i had with a deer a while ago, anyways, i had the frame checked and everything was good, kmember lined up they said. Anyways thought it was the lower control arm but it still looks like too much camber even with it all the way out.
What else could it be??
Thanks
Old 03-18-2004, 07:57 PM
wrencher
wrencher's Avatar
Was it on an alignment rack or "eyeballing it" it looks wrong?
Old 03-20-2004, 04:04 AM
BADz2ATE's Avatar
on the strut you could have bent the studs ------ i align semi's but have done a car or two and saw one with bent strut studs and that caused the readings to be way off.
Mike
