Gears & Axles - Where can I but a plastic yoke?
Brian2001SS
01-29-2012, 04:06 PM
Want to pull the driveshaft so I can paint the underside, but need a temp yoke to keep the fluid from coming out of the tranny. Any sponsors sell something like this?
can't you just lift the rearend slightly higher
so all the fluid is going towards the front instead of it going
out the tail.
Oldsmobility85
01-31-2012, 07:21 PM
Yeah if the car sits level u will lose only minimal fluid.
2QuikTA
01-31-2012, 10:16 PM
My haynes manual just says to wrap a plastic bag over the trans housing.
Brian2001SS
02-01-2012, 04:44 PM
Thanks guys. Car is setting level, so maybe I will try the bag thing. Then again I'm unsure how that will keep the fluid in.
I just thought a plastic yoke was a common thing. Guess not.
jbridwelltransam
02-01-2012, 06:34 PM
I just used a yoke that I had laying around.
jimmyblue
02-01-2012, 06:52 PM
Call it an excuse for an early trans fluid & filter change?
I bet any boneyard has a surplus of stock steel driveshafts
that nobody wants, and a bent one would go for roughly
nothing. Little sawzall session and there's your plug.
01BlackCamaroSS
02-01-2012, 07:13 PM
Harbor frieght sells a plug for $6 bucks
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
