Turning crank by hand?
have the motor on the stand, stripped. I installed my crank and main bearings. 3 mains are set at .0018" of clearance, 2 mains are set at .0016" of clearance. My question is how easy should the crank turn? should it turn like butter, like sliding on ice? or should it turn with just a tiny bit of pressure? i ask because it seems to turn really easy but, for example if i tun the motor over by hand 15 times it turns really easy and nice but 2 out of those 15 times it feels like it hits a tinny tinny tight spot... nothing major just a tiny tight spot, not real tight but a slight bit more effort to turn then the rest... is this normal, maybe just machining that is off a tiny bit?
p.s. i followed the specs for setting the thruster bearing and torqued all the stock main bolts per spec and sequence.
It feels like to me there is a tight spot when turning the crank. If i stick my ear in the bore i can hear a slight friction noise when i feel the tight spot. as soon as it passes that spot i cant hear anything.
i pulled the main caps off this morning and yeah something is diffidently not right. main cap bearing #1 looks ok #2 looks scraped but you cant feel it with your finger, #3 has a little scrapping, #4 has the same amount of scraping as #2, #5 looks ok. Pulled the crank out, the journals look good, the main bearings in the crank are fucked, they all look like they have scrapings (cant feel any of them by hand). it almost looks like debree caused the scraps but i cant find any debree. I cleaned the crank before installing (or so i thought), blew out the oil holes, wiped journals and entire crank down with solvent. Any one have any ideas?
im not going to run these bearings so looks like I need a new set quick status.
I will get some pics up in a few
Uploaded with ImageShack.us
Did you blow out all the oil holes? It's a must and pull the barbell restricter out and blow it out, too. You may want to get the crank mic'ed, too. Could be out of round. Are you using main bolts or studs? If studs it should be align honed. Just a few thoughts.
if it was debree that was causing my issue then shouldnt the crank have been harder to turn the entire time. the crank coasts like an ice hooky puck on ice untill it hit the tight spot then it takes 17 ft/lbs to get past that spot, then coasts again
problem fixed, it turns out i didn't have the thrust bearing set properly. i took everything out, cleaned, lubed and reinstalled (this time beating the crank harder than last time). everything turns over by hand like glass. im re using the bearings, turns out it was just the protective coating that was wore off
by the way your interior looks sick
Thanks. I miss that interior...haha. Hopefully if I get this 6.0 put together I get to enjoy it sometime soon.
Ok. Big dead blow it is. Thats pretty much what Ive read, but I figured I would get all the input I can. A little more tear down, and a crank kit, and I should be there!
J.
J.
You should not have to beat on the crank. Just pry it forward and rearword with a flat bar or big screwdriver or brass hammer. The protective coating is sometimes removed by hand bysome builders.
