Any guesses what these dual springs might be?
Old 01-30-2012, 09:29 AM
mattster03's Avatar
Default Any guesses what these dual springs might be?
I am hoping that someone might be able to identify these mystery dual springs that came on an engine that I recently purchased. There are no obvious identifications such as a colored stripe, etc. PAC 1521, Comp 9521, Patriot?
Old 01-30-2012, 12:01 PM
01ssreda4's Avatar
I think the Patriots, Lunatis, and PRC duals are all gold in color. Those appear to be titanium retainers so that should help narrow it down.
Old 01-30-2012, 01:13 PM
mattster03's Avatar
Thanks for the input... titanium would be a nice little bonus! If I would remove one of the springs and measure the height with a calipers, would this help determine the springs or do spring vendors normally not supply this info?
Old 01-30-2012, 02:23 PM
TurboBuick6's Avatar
If you can give us ID and OD of inner and outer as well as pictures closer up of them off.
Old 01-30-2012, 02:45 PM
mattster03's Avatar
I will pull one tonight and PM you the dimensions
Old 01-30-2012, 02:56 PM
wildcamaro's Avatar
I bought the patriot gold kit with titanium retainers....those do look like them, that's my beat guess
Old 01-30-2012, 04:04 PM
JS01's Avatar
From the retainers/locks it looks alot like a Patriot Gold spring kit. If you get them pressure tested that will tell you what really matters.
Old 01-30-2012, 09:48 PM
studderin's Avatar
looks like the patiot ret. setup. thats the super7 lock for sure. is the inner sping gold? l
Old 02-01-2012, 10:06 AM
mattster03's Avatar
Inner springs are not gold. Here are the dimensions I pulled w/ a calipers:
Outer Spring:
OD: 1.2960"
Wire Diameter: 0.1735"
Inner Spring:
OD: 0.9480"
Wire DIamter: 0.1340"
Outer springs have a slight brown tinge, the picture above really doesn't show it. The inner springs are darker and closer to grey.
