'00' trans am rear end
Old 01-30-2012, 06:10 PM
target1911's Avatar
Default '00' trans am rear end
Car....
00' Trans Am. Not WS6. 180k mi. All factory stock. Daily driver
Problems......loud whine..almost goes away in right curve/turn
Sometimes the rear won't lock both tires.
Questions.....
What RE do I have?
Gears ratio?
I'm guessing I have to replace the rear end and all bearings
What are my options?
Factory or aftermkt?
Rebuild it?
I want to keep factory ratio......mostly due to not wanting to lose fuel mileage
Old 01-30-2012, 06:31 PM
LS1Tech Premium Sponsor
ssvert99's Avatar
if you don't plan on doing any racing with the car I would rebuild it.
*get a real good used or new AAM ring and pinion set. This is what the factory used and is much better than most of the aftermarket gears that will make noise.
*get a Eaton posi unit first... very durable and rebuildable.
*replace all the bearings and seals
*use a solid pinion spacer to set pinion bearing preload instead of a crush sleeve.
*install a LPW rear girdle cover instead of the factory sheet metal one.
it will cost ya a few bucks if you do it right this way, but if you don't abuse the car at all it will last a long time. Give us a call if you need help with these parts... we have a real good deal on anything for your f-body rearend and suspension.
Old 01-30-2012, 09:43 PM
target1911's Avatar
Next question.....
I located a used rearend. It from an 02 ws6 with 30k on it for really cheap. Will it fit AND work properly in my car?
Forgot to add that mine is an auto.
Old 01-30-2012, 11:11 PM
target1911's Avatar
Not sure if this will be a problem....the rearend is from a 6sp car and mine is an auto. Could I just swap my traction control to the other rearend?
Old 01-31-2012, 06:31 AM
FirstYrLS1Z's Avatar
your auto could be 2.73(standard GU2) or 3.23(optional GU5),6 speed is 3.42.
If yours is 4 channel traction control and potential swap rearend is 3 channel ABS only,you'd have to pull(4) all axles and put your backing plates onto the rear.
Old 01-31-2012, 08:09 AM
INMY01TA's Avatar
If it's from a six speed it would have 3:42 gears, an improvement for your auto.
Old 01-31-2012, 12:38 PM
target1911's Avatar
An improvement for performance but what will it do for gas mileage?
Are those parts easy to swap?
Old 01-31-2012, 03:36 PM
you never stated what your rear ratio is in the 00' auto trans am !
