Mike Norris
01-30-2012, 06:57 PM
Hey All,
As most folks know I have been traveling back to FL at least one every couple months to do tuning for a couple shops as well as individual clients and it seems my trips are coming along more and more often. When folks have asked who I suggest people go to in the Cent FL area, I mention the typical names and it seems most folks are looking for someone besides the current shops out there. The reasons range from lack of customer service to the typical too high of pricing. The pricing thing I generally do not have an issue with for the most part as overhead can be a killer for sure, but customer service needs to be number one for sure.
So I have been working with a new shop in Central FL for a little while now and they will be offering packages built to my specs and utilizing my tuning. Though it is a new shop it is no stranger to the LS engine family and has probably worked on a lot of folks cars here over the years.
This is a full service shop and has the capabilities to do just about anything bolt on wise as well as some light fabrication. There is no dyno at this facility, at least yet. But tuning will be done as I travel that way about once a month or so for other shops and clients. For vehicles done in between trips a base tune will be supplied till I can get that way if it seems it will be a while.
Base cam swap packages for 98-02 F-bodies and 97-04 Corvettes will start at $2195 and include:
Choise of Comp Cams Camshaft
Comp 26918 Single Springs
Moly Pushrods
All Necessary Gaskets & Seals
Crank Bolt
ARP Cam Gear Bolts
Oil & Filter
Professional Install
Complete Idle, Driveability and Power Chassis Dyno Tune
Upgrading to a Dual Valve Spring Package adds $100
Of course there are other add-ons such as a HD timing chain, HV oil pump, underdrive pulley and so on, but I feel this is at least a good base package to build off of and have a dollar figure to work with.
Feel free to contact me for more info if need be. You can ask here, PM me, call me weekdays at 407-616-2518 or e-mail me at thevettedr@aol.com
Thanks everyone !!
Mike Norris
Moly Pushrods
Crank Bolt
ARP Cam Gear Bolts
Oil & Filter
Thanks everyone !!
Mike Norris
