Battery located turbo
I am looking at mounting a 76mm turbo in my battery location, i want to leave may radiator in the stock spot and mount some pusher fans on the front... I just want to know if anyone has had any problems with mounting theres in this location?
I am working on a setup like that except hopefully the cooling system will all be stock. Stock alternator location, stock cooling system, front sway bar stays... Check out my build thread for more details if you want. Haven't installed everything yet so not sure what all is actually going to work out and what won't.
Ahh, didn't know you wanted to do away with the a/c. My kit was built with the intent of retaining the a/c without relocating the alternator. I would still put a blanket around the turbo if you want it that close to the radiator.
Let me know if you want pics.
Tim
Tim
88mm t4 with 4" downpipe which still needs to be routed through bmr tubular k-member. I'm using a pusher and puller fan combo and the A/c is removed temporarily untill I can relocate condenser.
