rear brake pad install
Old 03-18-2004, 07:34 PM
clotus's Avatar
Default rear brake pad install
How hard is it to change the rear brake pads myself. I have never broken down brakes before, but i have painted the calipers. I am pretty good with tools, and I don't want to pay someone with less education than me do the install if I can do it myself, plus I want to learn, and when better than rear brakes. So is it really difficult, any special tools needed, and are there online instructions I can follow? Also, what pads do you guys reccommned. Thanks.
-Kyle
Old 03-18-2004, 10:09 PM
Copy & Paste Moderator
VIP1's Avatar
Its easy. Here are some sites to help out:
www.installuniversity.com
www.ls1howto.com
www.projecttransam.com
--VIP1
Old 03-18-2004, 10:14 PM
mitchntx's Avatar
The OEM pads are very good street pads
Old 03-19-2004, 05:08 PM
NHRATA01's Avatar
I had never done brakes before, and mostly stuck to oil changes and general maintenance on my cars. I was amazed how easy it was to do the brakes on our cars. Definitely go for it yourself.
Old 03-19-2004, 05:53 PM
Fulton 1's Avatar
Yup, as stated above these brakes are very "user friendly" - especially if you're just replacing pads. Definitely don't pay someone to do the work unless you just don't have time or something.
Old 03-19-2004, 06:43 PM
Jeffs99SS's Avatar
very simple to do. most rear brakes require a caliper tool to twist the piston as you compress it back into the caliper. other than that, it's all basic tools.
Jeff
Old 03-19-2004, 07:38 PM
Fulton 1's Avatar
Jeff
I've never used anything more than a big (maybe 8") C-clamp to compress the piston(s) - never had a problem with that approach.
Old 03-19-2004, 08:28 PM
mitchntx's Avatar
Some vehicles integrate the parking brake into the rear caliper.
It's done by "unscrewing" the outer piston from a threaded inner piston which is actually the sealing surface for the brake piston.
So, a C clamp will still work, but it won't be enough to get the piston assy. all the way back into the caliper to fit over new pads.
Old 03-19-2004, 09:00 PM
VIP1's Avatar
The rear brakes on my mother's car are like that, but not our F-bodies. They are simpler, all you need to compress the calipers is a big C-clamp.
(BTW, I dont have the special tool to twist-in the calipers. I just use some average sized needle nose pliers and a steady hand to twist them in since there is a big plus sign cut into the pistons in her rear calipers.)
--VIP1
Old 03-19-2004, 09:21 PM
mitchntx's Avatar
The e-brake design is the reason why the cost of rear rotors is twice that of front rotors.
Quick Reply: rear brake pad install
