FS:BMR Rad.support,160* tstat *NEW*, TR6s,Bosch starter *NEW*,Barry Grant Fuel Cooler
Category: Accessories
Price: $0
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): CA
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
-SOLD 160* thermostat for LS1 new never used. Went to a aster bracket with my new motor which required a different pump/tstat set up. $40 shipped.
-SOLD NGK TR6s brand new never fired. They were placed in my motor because I had intentions of using them before switching to higher boost application. They have been threaded in lightly by hand on my new motor just to keep dust out. make offer.
-Bosch starter brand new. Does not include relay solenoid. This starter did not fit with my American Racing 1 7/8" headers, did not clear. Since the only reason I purchased it was because I broke the contact on the OEM solenoid I just swapped them out. If your relay solenoid is good and need just the starter portion then this will work for you. Asking $50 shipped.
-SOLD BMR radiator support. Powdercoated black. Has minor scratches and had to to drill a couple holes for mounting radiator farther up. $45 shipped.
-Barry Grant "Heat Sink" fuel cooler. I was going to use this in my return line but ended up going with a larger cooler. This is the -8AN style setup. It has a removable check ball in one end so if you want to retain pressure for start up you can leave the check ball in or remove it if you like. New and never used. Retail is $90 + shipping. Im asking $50 + shipping.
Thanks.
