whats a good cam for nitrous?
Hey guys a little please, ok I have a 2000 camaro ss ls6 intake long tubes full bolt ons I'm looking to do a cam and a wet 100 shot but want to get the best bang for my buck! Was thinking about ms3 or ms4 is that a good choice or is there something better?
would a ms4 take well to a 250-300 shot?
An ms4 take a max effort setup to be worth using.
If you are near full weight, think a 3600 stall is fine, worried about mpg, or the like dont use that cam. It also take a very good tune to get it done correctly.
i am a full weight car with a PY3600. i plan on spraying 200-300 shot at the car.
If anyone runs stock 241 heads with MS4 and want to spray above 250 , I would say it won't response nitrous with those stock heads , I done that before with TNT F2 and put 250 jets the gains was maximum 220hp , We did this same setup with Trick flow heads 59cc and MS4 112 lobe separation and put down 700rwhp on 250shot , We can do 300shot with any issues but first should runs 1/7-8 headers to spray that much to avoid any issues
Captain Double Post
there is so much more that goes into building a car to take a big hit, rearend, suspension, tires, fuel etc ,tune. i would start off small if your the new kid on the block, once you start learning about things then move up,ms3.4 are great cams but max effort cams are not a budget way of going fast, you need every lil bit you can get with them,
