3 custom cams for lq9/l92 combo
Old 02-01-2012, 01:26 PM
xdanny510x's Avatar
Default 3 custom cams for lq9/l92 combo
Which of these cams would give me the best hp/tq over all..driveability isnt a issue...
1st cam is a custom spec
235/247 .621/.624 113+3
2nd is custom as well
237/252/610/632/113+3
And the other is
251/259 .6**/.6** 111 LSA...
Old 02-01-2012, 02:08 PM
sweetC5's Avatar
I would go with the first one, the last cam I dont like much. Seems like the last cam would be very peaky and give up to much mid range. Thats just based on my own research and opinion, not facts Depends on car setup too though.
Old 02-01-2012, 02:33 PM
xdanny510x's Avatar
Set up is lq9404 l92 heads milled to 64cc... Comp. is around 11:8:1 th400.. With 4400 stall. 12 bolt rear end
Old 02-01-2012, 02:50 PM
Tainted's Avatar
The first one. Donkey dick cams dont always perform the best
Old 02-01-2012, 04:32 PM
topbrent's Avatar
So your setup is: 11:8:1, 404" with L92 heads, th400, 4400 stall
First cam (235/247 .621/.624 113+3) would probably pull like a freight train in a 404".
Vehicle weight? - Stock heads or Ported? - What intake are you running?
Who spec'ed the cams for you? (just curious)
Old 02-01-2012, 06:50 PM
xdanny510x's Avatar
Ported l92 heads..fast 102 with fast 102tb...
Old 02-01-2012, 09:58 PM
cam75w/ls1's Avatar
My 6.0 w/ L92's put down 502 to the wheels on a 238/250 cam. My lift is only .604/.598 on a 113+3. Wanted some longevity on the valve springs. It pulls like a raped ape after 3k rpm's.
Attached Thumbnails 3 custom cams for lq9/l92 combo-imag0014.jpg
Old 02-02-2012, 05:56 AM
cabel1's Avatar
Nice I'm building a 6.2 with ported L92's trying to figure out a cam. 3600lbs, 4L80E, 4.11's 28" tire, 4400 converter LS3 intake.
Old 02-02-2012, 03:00 PM
87silverbullet's Avatar
Since drivability is not a concern. Go with the last one. Here are some threads from TSP on that last cam. 640+ flywheel hp
https://ls1tech.com/forums/dynamomet...o-results.html
https://ls1tech.com/forums/generatio...ml#post6694298
Old 02-05-2012, 07:36 AM
cam75w/ls1's Avatar
640hp done by a 418 stroker though.
Old 02-05-2012, 08:59 AM
Read his combo above. 14 cubes is not going to matter much in cam choice and he doesn't care about driveability.
Old 02-05-2012, 10:49 AM
xdanny510x's Avatar
So the first cam will pull like a freight train? Is that good lol..a train seems slow... Lol now if it was like a raped aped id be quick haha
Old 02-05-2012, 11:09 AM
Tainted's Avatar
Or a ho in stilletos booking it from her pimp!
Quick Reply: 3 custom cams for lq9/l92 combo
