Catback With Turbo?
Catback With Turbo?
I have a hooker catback on my car currently and was planning on re-using it until last night a friend and I were talking. He said he thought it might cause a restriction. It is 3" diameter to the muffler and dual 2.5" out if that means anything.
The setup will be (as of now... it keeps growing lol):
Stock bottom end LQ4
EPP cam
LS3 heads
PT76gts @ around or less than 10 psi
.96 a/r
Do most people run through a catback with a cutout? Or do they dump it? If dumped, how loud is it? I know the turbo will act as a muffler to an extent.
Thanks for the help
EPP cam
LS3 heads
.96 a/r
Thanks for the help
cutout definitely I would add in there. Do as large pipe as you can to the cutout and then have the other side of the cutout go down into your 3'' catback if you want to keep it. Most guys just run the DP into a "turbo" type muffler, aka, very litttle anything inside hindering flow. Then dump it under the car. Unless you have a race car and then it usually gets to exit before or right after the front tire thru a fender. You said you needed tips for your car to look right, well why not thru the front fenders?
With the added turbo, the car doesnt "sound" super loud and rumbly all the time like n/a as the gases are being used again and not driven out the rear of the car constantly at such a high rate. It will still scream at WOT tho!
I run my stock slp dual dual muffler most of the time. I have a 4" electric cutout right after the down pipe and it's ungodly loud when open. I love the way it sounds through the dual dual, still has a nice rumble but not annoyingly loud. It does cause a little slower spool and probably is a restriction of around 30 + hp. I still managed to make 720 rwhp with a stock bottom end ls1 and 76gts on 11.5lbs through the stock dual dual
If it is a fairly straight through design and not a multi-chamber muffler, I am sure it will be fine. It is more a function of design than just having a muffler. I plan on using twin 3" Magnaflow straight through style mufflers on my twin turbo build.
A cutout is not mandatory by any means.
With my first kit, I tried it with my Magnaflow catback. Frost told me to try dumping it under the car before he final tuned it. The car picked up noticable power without changing anything else. It spooled quicker and pulled harder & longer up top. I used a 3" Dynomax Bullet w/ a turndown at the axle.
Now with my truck manifold kit, I used a cutout to dump at the axle or to use the Magnaflow. I haven't compared the difference from open to closed yet.
Does anyone have a dyno comparison of a turbo car running with the cutout open for one run and closed for one to see hard numbers? If no one does i will..im putting a cutout on the exhaust of my front mount gt45 kit..i should hope to see some concrete proof they help turbo cars..
Also interested in knowing dyno results. I think what I will do is run the exhaust out through the catback and just have a manual cutout for now. If it holds me back 30 hp I guess that just saves the ten bolt that much longer. lol
