Generation IV External Engine - Intake Manifold and Throttle Body porting without the wait
peakspeedshop
02-02-2012, 02:13 PM
Be up and running with a ported manifold and throttle body the same day! No more waiting 2 weeks with your vehicle down while getting your parts ported!
Peak Speed Shop has ported LS2, LS3, L76 and LS7 manifolds and throttle bodies in stock. Simply pay a refundable core charge until we receive your removed parts back.
http://www.peakspeedshop.com/images/LS2%20Intake%20Manifold%20Before%20Small.jpg
http://www.peakspeedshop.com/images/LS2%20port%20before%20035%20small.jpghttp://www.peakspeedshop.com/images/LS2%20port%20after%20small.jpg
Factory LS2 runner not ported (at top). Runner precision ported by Peak Speed Shop (above)
http://www.peakspeedshop.com/images/LS2%20Plenum%20after%20small.jpg http://www.peakspeedshop.com/images/L76%20Plenum%20Radical%20Ported.jpg
Plenum with Basic Porting (at top). Plenum with Radical Porting (above -- all center posts removed)
Porting prices start at just $250 for Basic Porting and only $75 more to have your Throttle Body ported at the same time!
Refundable core charges are additional if you want us to ship one to you right away out of our stock.
TO ORDER, go to http://www.peakspeedshop.com/ (http://www.peakspeedshop.com/)
Listen to what these customers have to say about the quality of our porting work....
"The car picks up so much nicer now, with the top end pulling harder then ever. I always felt that I would get a instant tq rush pressing the gas, and then the power kind of fell off a little. Now I get the same tq rush, and once I hit around 4500rpm, the car just wakes up! Big difference! Thank you again Bob for such a great job! I'm glad I had my manifold ported keeping my stock look! I would do it again in a heart beat!"
Kennan - GA (LS2 Intake Manifold Radical Porting)
"Both pieces came back looking great - just as advertised. The set up runs great and I can feel a difference in throttle response. I haven't really jumped on it yet as the weather up here has been lousy and I'm still on last years gas."
Ken - WA (LS3 Intake Manifold Radical Porting & Throttle Body ported)
“Just had mine done (radical porting) and the work was very good. I've got long tubes, ported throttle body and a CAI and will be getting tuned this week. Bump for a quality service.”
Mike - MO (LS7 Intake Manifold Radically ported)
IrocZTransAm
02-05-2012, 12:03 AM
This sounds great. What is the core charge?
peakspeedshop
02-05-2012, 09:16 AM
For an LS2, the refundable core charge is $250 on the intake manifold and $300 on th throttle body.
IrocZTransAm
02-06-2012, 08:40 PM
Whats the benefits of running a ports LS2 manifold vs an LS6? I read the LS6 flows better but the price for a ported LS2 is pretty good
a-low
02-07-2012, 06:48 AM
I didnt see it in the website but do you guys do ls6 intakes?
peakspeedshop
02-07-2012, 02:00 PM
Yes we do Basic Porting on the LS6 manifolds. However, we haven't seen much for gains by porting the LS6.
Many LS1 owners who are looking for improvement in performance, search for an LS6 intake manifold and see 5-10 rwhp gain simply by bolting it on. It's a good choice, but they are getting harder to find and prices are creeping higher.
Many say the LS2 intake manifold is a step backward from the LS1 and they are right if you consider simply the stock unported LS2 manifold. The reason for this is that the LS2 intake manifold switched to a new process that sonic welded three pieces together. The result is that where the pieces joined together they rarely butt together properly and there are ridges and bumps that disrupt airflow. However, porting the LS2 manifold smooths all of these transitions. Basic Porting of an LS2 manifold will generally get up to 5 rwhp better than the LS6. Our Radical porting of the LS2 manifold generally gains an additional 5 rwhp over the basic porting.
Another advantage to the LS2 intake manifold is that it allows you to step up to a 90mm throttle body from the LS1 78mm throttle body. The cost of the LS2 intake manifold is less than an LS6 manifold, however, that is offset by the additional cost of having to pick up the LS2 fuel rails, injectors and throttle body as well as the cost for porting. In the end, though, it is my opinion that you will have a better intake system than the LS6/78mm setup at a cost that is 50% lower than a FAST setup.
We sell the FAST 102's. For an LS1 setup with fuel rails, a ported 90mm LS2 throttle body and wiring adapter the cost is $1505.
We happen to have two radically ported LS2 intake manifold setups on hand that includes fuel rails, ported 90mm LS2 throttle body and wiring adapter. One includes injectors and the other does not. The setup with injectors (20,000 miles on them) is $1,000. Without injectors it is $900.
AJG383
02-07-2012, 08:51 PM
As soon as spring gets here, I am bringing my FAST down for you guys to port and maybe powdercoat.
peakspeedshop
02-08-2012, 09:10 AM
Great! We look forward to doing the work on your FAST manifold.
pistonpopper
02-10-2012, 05:26 PM
Bob ported, my Fast 102 about a year ago. Fantastic to deal with. He went the extra mile working with TEA to make sure the intake was port matched. Need more people like him in our hobby! :cheers:
06vLo
02-12-2012, 03:16 AM
Bought my radical mani from them last year, great quality work and great service.
thenovaproject
02-16-2012, 11:28 AM
I got a stock ls2 mani and tb would like my own back.running a 5.3 gen IV motor running a 275 hr cam 799 heads long tubes cai .how far should that go how much how long..?
Thank you in advance
peakspeedshop
02-16-2012, 11:40 AM
Sending you a PM.
Double J
03-07-2012, 04:48 PM
Hi -What kind of HP/TRQ increase can I expect porting my LS3 Manifold? I have a New LS3 418 CI Stroker, Forged Internals, Kooks Long Tubes VS, Just buying a FAST Manifold? Will I gain any low end torque?
peakspeedshop
03-07-2012, 05:24 PM
We also sell ported FAST manifolds. Our radically ported LS3 manifold generally gets around 14rwhp gain over stock which is about the same as the unported FAST. The ported FAST for the LS3 gets around a 22rwhp gain over stock. In both cases, the torque and rwhp gains are in the 3500 to 6000 rpm range.
peakspeedshop
03-08-2012, 10:46 AM
to the top
The_One
03-10-2012, 12:03 PM
Have any dyno charts for a stock LS3 showing gains?
peakspeedshop
03-12-2012, 01:38 PM
Yes. Go to our website at http://www.peakspeedshop.com/. You will see we have a page of Dyno results and LS3 is included. Also, you can look at the Customer Feedback on our site to see what other LS3 owners have said about the porting results.
peakspeedshop
03-14-2012, 01:36 PM
Thank you for your orders! We enjoy serving the LS1Tech members. :cheers:
peakspeedshop
03-19-2012, 11:53 AM
to the top
peakspeedshop
03-22-2012, 11:02 AM
to the top
I wouldn't have made the # I made w/o my Peak Speed Shop Radical Manifold & TB... Thx Bob !:thumb:
Bandit2000
03-25-2012, 03:46 PM
can you guys suggest a good throttle body for me besides the fast. i need a 4 bolt ls2 throttle body i want one that seals well and is relatively cheap. id like to have my manifold and tb ported by you guys..thanks
edit: btw its a 96mm intake so id like at least a 90mm tb, also its needs to be a drive by cable tb because its going on an ls1
peakspeedshop
03-26-2012, 10:51 AM
LS1 stock 78mm throttle bodies are drive by wire. We sell ported stock LS2 90mm throttle bodies that are drive by wire for $375. You would need a wiring harness adapter that we sell for $54.95 that allows you to plug this into your LS1 wiring harness.
If you truely need a drive by cable throttle body, we sell the Nick Williams in both 92mm and 102mm for $375.
2win_SS
06-06-2012, 07:47 PM
How much do u charge to port a stock 78TB for LS1?
peakspeedshop
06-07-2012, 11:25 AM
We charge $125 plus for $15 return shipping. Simply go to our web site at http://www.peakspeedshop.com/ and fill out a Purchase Order. Payment and shipping instructions are on the Purchase Order.
2win_SS
06-08-2012, 06:14 AM
Sweet. Thanks
peakspeedshop
06-11-2012, 02:27 PM
Sweet. Thanks
You're welcome! We look forward to porting your throttle body.
azchevydude
06-13-2012, 11:39 AM
How do i order from website if i have a 01 truck intake i want ported?
peakspeedshop
06-13-2012, 06:09 PM
Sending you a PM.
peakspeedshop
06-18-2012, 02:32 PM
to the top
peakspeedshop
06-25-2012, 04:13 PM
to the top
peakspeedshop
07-02-2012, 02:08 PM
to the top
peakspeedshop
07-10-2012, 06:19 PM
to the top
peakspeedshop
07-16-2012, 04:52 PM
to the top
peakspeedshop
07-30-2012, 11:54 AM
to the top
peakspeedshop
08-02-2012, 02:15 PM
Go to http://peakspeedshop.com/Zen_Cart/ to check out our new online store.
Order intake manifold porting, throttle body porting, FAST products plus intake parts.
Now, you no longer need to wait while you ship us your parts for porting. Pay a core charge to get the most common LS2, LS3 and LS7 parts from our inventory and be up and running the same day! Core charges are refundable once we receive your cores back. Order online at our new store!
For more information on Peak Speed Shop Services, go to our regular website at http://www.peakspeedshop.com/ . You can access our store from there, too.
peakspeedshop
08-07-2012, 12:16 PM
to the top
peakspeedshop
08-15-2012, 05:04 PM
to the top
peakspeedshop
08-27-2012, 12:26 PM
to the top
stryder
08-28-2012, 12:59 AM
I have a fast 92 and a ls2 TB pm me price to port them please if you can do these. I would send them to you so i don't have to deal with core prices if thats ok.
peakspeedshop
08-28-2012, 11:21 AM
We would be happy to port these for you. Just sent you a PM with costs and shipping instructions.
peakspeedshop
09-05-2012, 11:26 AM
to the top
peakspeedshop
09-18-2012, 12:44 PM
to the top
peakspeedshop
10-01-2012, 12:09 PM
to the top
peakspeedshop
10-08-2012, 01:32 PM
We also port FAST manifolds and GM Truck Manifolds!
Find out more at our website: http://www.peakspeedshop.com/
http://peakspeedshop.com/Zen_Cart/images/categories/FAST102.jpg http://peakspeedshop.com/Zen_Cart/images/L92%20manifold%20small.jpg
peakspeedshop
10-29-2012, 03:34 PM
to the top
Wish I'd seen this prior to buttoning up my LS3 based 416. Can you give me an estimate of the power gains porting my edelbrock 90mm TB and stock LS3 intake, as well as cost to send them in vs you sending me some one of your TB & intake already ported? Thanks.
peakspeedshop
11-14-2012, 11:29 AM
Sending you a PM.
ngeno626
11-15-2012, 01:00 PM
ports look awesome id love to see one in person
peakspeedshop
11-26-2012, 06:57 PM
Put a Peak Speed Shop Gift Certificate on your Christmas list!
http://peakspeedshop.com/Zen_Cart/images/gift_certificates/gv.gif
Apply it towards porting your intake or throttle body. Or, apply it towards any of the products sold at our store:
FAST manifolds
FAST and Nick Williams throttle bodies
Halltech and Breathless Performance cold air intakes
Billet style fuel rails
Torrent fuel lines
SLP and Lingenfelter Mass Air Flow sensors
and more!
To order gift certificates, go to http://peakspeedshop.com/Zen_Cart/index.php?main_page=product_info&cPath=21&products_id=47
PM accidently erased. Tell me again the cost to port my existing LS3 intake as well as my edelbrock TB and what gains I would see. As an option, would my edelbrock TB work with one of your fast intakes, and what gains to be seen with it an my ported TB as well as cost and if I could get credited for my LS3 intake as well making sure it all works with my setup, cc, ect... Thanks.
peakspeedshop
11-29-2012, 10:34 AM
Sending you a PM.
peakspeedshop
12-11-2012, 05:22 PM
to the top
peakspeedshop
01-08-2013, 01:54 PM
Winter is a great time to contact Peak Speed Shop in order to have all of your power modifications done by Spring. Order your intake parts and porting now by going to our web store at http://peakspeedshop.com/Zen_Cart/
peakspeedshop
01-21-2013, 10:19 PM
to the top
peakspeedshop
02-07-2013, 11:10 AM
to the top
peakspeedshop
02-19-2013, 11:04 AM
Thank you for your orders, LS1Tech members. We appreciate your business.:cheers:
peakspeedshop
03-11-2013, 10:55 AM
To the top
peakspeedshop
03-18-2013, 05:57 PM
to the top
Cost to port an LS3 intake?
peakspeedshop
04-04-2013, 11:39 AM
$370 for Radical Porting
Go to our website to see the difference and to order http://www.peakspeedshop.com/
peakspeedshop
04-16-2013, 12:39 PM
If we port your throttle body at the same time as your intake manifold, we charge just $75 additional. That's $50 off the regular price!
http://peakspeedshop.com/Zen_Cart/images/LS3%20TB%20PortedSmall.jpg
To order, go to http://peakspeedshop.com/Zen_Cart/ or call us at 719-651-1952.
peakspeedshop
04-23-2013, 01:44 PM
Just received this feedback today from a recent customer.....
"Bob from Peak Speed Shop was great... he ported my FAST intake and ported my throttle body and I picked up power throughout the RPM range.... over 25 hp, and 15 ft-lbs of torque before and after on same dyno (after retune). Quick turnaround, runners were ported evenly, but not overported (still saw witness marks). All in all, fantastic and reasonably priced "
A.T. – Illinois (FAST 92 ported and Throttle Body ported– LS6)
See more customer testimonials at http://www.peakspeedshop.com/feedback.xhtml
peakspeedshop
05-15-2013, 06:01 PM
to the top
