Generation IV External Engine - MAF and lid for Trans Am LS7 swap
man2004
02-02-2012, 03:27 PM
We are installing the LS7 in the next few weeks. The LS7 has stock heads, stock intake, Katech Torquer LS7 cam, 1 and 7/8 Kooks long tubes (engine dyno made 619 HP/578 Torque). The car ('98 TA vert) has a rebuilt T56 M6, new drive shaft, new 9" with 411's, SFC's, LCA's, and torque arm. We plan to give it light spray 100-150 shot max. We are considering speed density tuning. But, I am concerned about the temp fluctuations in South FL. And, I do not have a stock LS7 MAF. So, I am favoring using an aftermarket 100mm MAF. What MAF should I run with the LS7 (TSP vs. Lingenfelter)? Also, how can I get more air into this set up? Is it worth cutting up the front end to route more air into the MAF. I know most cars with smaller cubes (LS1) just have a FTP or SLP lid. But, with the 427, is it worth trying to get more air from below (Blackwing, SS, Chris1313, etc) or even a custom CAI through the fogs or cut center section?
Blk98Vert
02-02-2012, 03:50 PM
The 104 lid will be more than enough. You can add a ram air kit to help when you race if you want to
man2004
02-02-2012, 04:20 PM
Cool. Thanks!!! Maybe we should start a black on black 98 TA vert club! Lol:drive:
man2004
02-02-2012, 04:25 PM
What MAF are most guys running in a TA with a 427?
Bill00Formula
02-02-2012, 09:33 PM
Will you be running this car at the track? I have 2000 Formula with a 427 but have TFS 235s. I'd love to see how are cars compare (Ls7 heads versus TFS 235s). When I built mine I wasn't sure which heads to go with. Good luck.
Blk98Vert
02-02-2012, 11:13 PM
Sure why not lol, and the TSP MAF seems to be the most popular. Be sure to get a screen from Saxon to make sure the airflow is solid across the sensor
man2004
02-03-2012, 03:23 PM
I plan to run PBIR. I would really like to run the milemarker-1 race some time too!
PONTIAC SLP
02-06-2012, 08:33 PM
Stock LS7 heads flows 350CFM at 600 lift on the intake and don't know about TFS , 150 shoot is much on that bottom end , The LS7 valves intakes are not that strong to hold up that more power , I seen many of LS7 with stock valves falls and damaged the motor by falling the intake valves , Second thing the pistons are not strong and has weak top , third thing the rods bolts are very light and can't handle that much power of shoot
man2004
02-13-2012, 06:28 PM
Very good points! We are planning to run it NA at first. Down the road, we might spay. Fortunately, TEC build the engine with aftermarket (Mahle) pistons and rod bolts. I will need to check on the intake valves.
Bill00Formula
02-13-2012, 07:01 PM
Mike built mine as well in addition to alot of people I know. Surprised you don't have JE pistons. Seems like that was all he used. When do you expect to be up and running?
man2004
03-05-2012, 04:26 PM
The car was painted last week. So, the swap begins this week. I think we should be running by April Fools Day!
