will my ecu learn this set up
Old 02-03-2012, 09:10 AM
baldeagle432's Avatar
Default will my ecu learn this set up
ok im runing stage 3 cnc ls heads on a tourger v3 cam will the ecu learn it or do i need a tune i just cant afford it right now but i really miss my car and want to drive it i know tune is best but will it learn it enough to now blow up
Old 02-03-2012, 09:40 AM
thunderstruck507's Avatar
You will definitely need a tune.
I would also be surprised if you do not need larger than stock fuel injectors with that setup too.
Old 02-03-2012, 09:46 AM
redtan's Avatar
Nope, the computer does not learn wide open throttle only part throttle.
And even then, you still want to tune it because it's not going to learn everything. You're going to have a tough time driving an untuned car even on the street.
Old 02-03-2012, 11:41 AM
PREDATOR-Z's Avatar
No GM pcm is not a AI.
Old 02-03-2012, 12:20 PM
01ssreda4's Avatar
Full tune is required.
