stock return line size?
I am connecting the return from the fpr to braided -6 an hose. I have removed the stock return line from the t block under the car and blocked off the hole. I want to connect the an return line to the factory return line under the car.
It still has the fitting on the end. Better to get a compression to an fitting or a 14mm x 1.5 to female to an?
What size is the stock return line?
if i'm understanding your question correctly, this is all you need if it's the same flare and all as it would be in the engine bay....http://www.jegs.com/i/JEGS-Performan...03100/10002/-1
