Sponsor Sales & Specials - Huron Speed Torque Converters
View Full Version : Huron Speed Torque Converters
Superman09
02-04-2012, 01:45 PM
Huron Speed is now pleased to offer Torque Converters. No matter the application, we can have you covered! These are made specifically for Huron Speed per YOUR order and needs. These are not off the shelf converters, but rather built to your specs for your application!
We can cover all applications, whether you have a 93-97 F-body, 98-02, TH400 converted, 2010+ Camaro A6, C5 Corvette, C6 Corvette A4 & A6... you name it, we can get it done!
We have categorized the converters into 2 main models, the C1 and the C2:
Huron Speed C1 Torque Converter
This converter is good for those cars that are stock, bolt-ons, cam only, NA applications, or even small nitrous use.
This converter is good up to 750 hp
Good for smaller nitrous use up to 4000 stall speed.
If you would like WOT lock-up, we highly recommend the C1.3 with the triple lock up discs
-Billet Cover, Billet Lock-up Piston
-9.5" Converter
-Standard is a single disc, triple disk is also available (WOT lock-up) (C1.3)
-All converters will have a BILLET cover, BILLET lock-up pistons, furnace brazed and tig welded fins, and balloon plates
Huron Speed C2 Torque Converter
This converter is good for those cars that are Boosted (Supercharged or Turbo) as well as higher Nitrous use.
This converter is good up to 1250 hp
If you would like WOT lock-up, we highly recommend the C2.3 with the triple lock up discs
-10.5" Converter
-Standard is a single disc, triple disk is also available (WOT lock-up) (C2.3)
All converters will have furnace brazed and tig welded fins, billet covers, balloon plates, and billet lockup pistons.
We can offer your desired Stall Speed rating from 3000 on up!
We can offer 9.5"-10.5" sizes as well depending on your power needs, as well as either single or triple disc lock-ups!
These converters will come with Huron Speed engraved on them along with a serial number so we can always identify the unit should you ever want to sell down the road!
Please view on the website for options and such, and as always if you have ANY questions, feel free to ask!
http://shop.huronspeedproducts.com/Torque-Converters_c17.htm
Also be sure to check us out on Facebook and "Like" us to keep in touch with all our current specials as well as our constant new product updates! :cheers:
Click here to check us out!
http://i833.photobucket.com/albums/zz253/Oh-Check/HuronSpeedFacebookSmall.jpg (http://www.facebook.com/HuronSpeed)
Interested in knowing what is inside your torque converters? No secrets here, VERY high quality components inside! :cheers:
Billet Cover, Huron Speed engraved!
http://i833.photobucket.com/albums/zz253/Oh-Check/2012-02-13_21-07-19_769.jpg
Billet lock-up piston back side!
http://i833.photobucket.com/albums/zz253/Oh-Check/2012-02-13_21-16-45_599.jpg
Front of lock-up piston, 1.5" wide, .070 thick material!
http://i833.photobucket.com/albums/zz253/Oh-Check/2012-02-13_21-16-53_873.jpg
Hardened 4140 Chromoly Pump Hub and Turbine Hub!
http://i833.photobucket.com/albums/zz253/Oh-Check/2012-02-13_21-17-12_883.jpg
Dual fin braced turbine!
http://i833.photobucket.com/albums/zz253/Oh-Check/2012-02-13_21-03-35_258.jpg
Comparison to a typical single fin braced turbine from the competitors!
http://i833.photobucket.com/albums/zz253/Oh-Check/2012-02-13_21-03-50_95.jpg
Superman09
02-07-2012, 12:46 PM
We have now categorized the Torque Converters into C1 and C2 models!
Superman09
02-13-2012, 09:34 PM
Check out the added pictures to see what goes inside of these torque converters! :cheers:
trbokmro
09-14-2012, 11:23 PM
am i missing something? i looked all over the site linked to the address above and didn't see 1 item for c5 converters........
Superman09
09-15-2012, 12:59 AM
Sorry, unfortunately this line of converters is no longer available.
