383 LS1 Clearancing
383 LS1 Clearancing
First 383 build (2004 LS1 GTO).
1. Will a Eagle 4" stroke crank and 6.125" rods require block clearancing?
2. Would a shop be able to do this at the same time as the cylinder honing(without the rotating assembly installed)?
Thanks
Thanks
2. Yes if they're worth taking your stuff to, should not cost more than around $125-150 to have this done if they're already doing the rest of the machine work.
