Sponsored by: DashLynx
Swapping gauge faces
Old 02-04-2012, 09:49 PM
00MaroVSix's Avatar
Default Swapping gauge faces
Hey guys,
If I order a replacement gauge cluster off ebay or something that is identical to mine, can I swap the factory gauge faces for one another? I messed up my current gauge face and want to order another cluster and swap the gauge faces so I can use a factory gauge face that isnt f*cked up. Is this possible? Its a 2000 camaro. Thanks.
Old 02-05-2012, 08:22 AM
maxplusten's Avatar
Well as far as rather it will light up right or not i cant say for sure... but after switching to a 6LE overlay i took my factory overlay and put it on a v6 camaro cluster (that i used to get the outer housing) and it still looks as good as it did in the car. I turned it into a wall piece in my living room and had eventually planed to light it up (never got around to it) but as far as the actual swaping of the gauges, i dont see any reason you couldnt. The backs on mine wernt messed up at all when i took them off.
Old 02-05-2012, 08:41 AM
kSStamp09's Avatar
yes it is glued on. i have replaced mine when i had my SS.
i no longer have it tho, i do still have the stock GM overlay in perfect condition, $55 shipped if interested..
Old 02-05-2012, 11:46 AM
00MaroVSix's Avatar
so the overlay is only held in with glue? how do you remove the overlays? i tried searching for a write up on replacing overlays but couldnt find anything......
Old 02-05-2012, 12:54 PM
kSStamp09's Avatar
yepp. just remove the needles and peel the old off. quite simple. just remember to put the needles back on exactly where they were.
Quick Reply: Swapping gauge faces
