supspt454
02-05-2012, 11:28 AM
Ive been reading several different things on the LS1 engine and moisture in the oil. Ok here is my situation:
While getting this engine into my Chevelle, chasing ignition problems, and everything else in general with installing the LS1, the PCV system was about the last thing that I have done for some reason. With that in mind, I have been running this engine off and on for about 4 months without the pcv. Once I got the PCV up and running yesterday, I did notice quite a bit of moisture collected in the filler cap with the typical white film. I pulled the dip stick, and the oil is clear, but has a very slight trace of milk. Before everyone tells me that I have a head gasket issue, which is possible, could this be because I haven't driven this car yet and really gotten the engine up to operating temp? Maybe since the pcv was not working, each of my 5 min runs has built enough moisture into the oil that it is contaminated? Just some thoughts. If I could post pictures from my phone I would, but I don't believe I can. Thanks for any comments
