Would I need a tune?
Old 02-05-2012, 03:34 PM
Rocker665's Avatar
Default Would I need a tune?
I got a 93 lt1 formula I was wondering if I put 36 lb injectors in if I would need a new tune? I have a dyno tune on it now and I gotta be maxing out the 21 lb injectors that are in it now thanks guys!
Old 02-05-2012, 03:51 PM
MUSTANGBRKR02's Avatar
Yes new injectors require a tune.
Old 02-05-2012, 03:52 PM
2xLS1's Avatar
You can't change injectors without changing the injector flow rate value in the calibration. Being a 93 you will need to have another chip made.
Old 02-05-2012, 06:28 PM
Rocker665's Avatar
Thats what I thought thanks!
Old 02-05-2012, 06:34 PM
Nexus9's Avatar
Injectors are made up of a small hole with a tapered pin in the hole (which seals it), and a solenoid at the back side of the pin which pulls it out of the hole, allowing fuel to spray through the hole. The amount of fuel sprayed through the hole is determined by the duration (length of time) that the pin is pulled back, and the pressure at the orifice, which is fuel rail pressure.
The ECM controls the pin, and the fuel pressure regulator controls the rail pressure. Both of these have not (yet) changed; BUT the 34 pound injectors have a larger orifice and a larger pin.
So, the duration is still the same, the pressure is still the same, but the hole is larger - your car will run rich until you change the duration of the injector (called the "pulse width") with a tuner.
Old 02-05-2012, 06:58 PM
gregrob's Avatar
You need to update the IFR and IOT for the new injectors...
Injector flow rate, and Injector Offset Table.
Quick Reply: Would I need a tune?
