Corvette Performance - c5 408 oil pan issue
View Full Version : c5 408 oil pan issue
silverbullitLS1
02-05-2012, 11:22 PM
I need some help here guys. Im putting a 408 in my 2000 frc and im in the process of putting all the covers and oil pan to the new motor but with the windage tray spacers the pick up tube hits the bottom of the oil pan and wont let it sit down completly and with out the spacers the rod bolts hit the windage tray. I need someone to clearly explain what they did to the windage tray to allow the stock oil pan to fit. If theres anything else that i need to know please help me out here guys the more info the better.
Oh and i did search the forum before I posted just couldnt find the right answer I guess, so dont bust my balls on that.
Thanks
Eddie
Ksths2
02-07-2012, 02:19 PM
Any news on this?
silverbullitLS1
02-08-2012, 11:30 PM
Yea I wanted to get everything to fit with out cutting up the windage tray. First I put 2 washers to space the tray up a little bit, then I cut a little bit on the left side of the windage tray(motor upside down, standing in front of the oil pump) so the rod bolts would clear, I used a ball pein hammer to beat down the tray where the pickup tube goes and pushed the pickup tube down to get the propper clearance from the bottom of the oil pan( I was told to have 1/2" clearance from the bottom). I also had to grind down some of the ridges(i guess thats what there called:confused:) on the front of the oil pan itself to be able to torque it down without having to worry about it cracking. I had to take the oil pan off so many times I was about to just break it:bang:
RLS!
02-13-2012, 07:11 AM
The MAST windage tray works great... you might consider buying that rather than fuss with the stock tray.
I'm working on an ERL 434ci for a C5. The MAST tray clears the rod bolts and works rather well with the C5 "batwing" pan (2-piece version). I did some very minor massaging to the tray to make it all fit...
http://i27.photobucket.com/albums/c151/rlsracing/photobucket-3143-1324786777916.jpg
http://i27.photobucket.com/albums/c151/rlsracing/photobucket-2732-1324786499793.jpg
http://i27.photobucket.com/albums/c151/rlsracing/photobucket-1592-1324786431345.jpg
Their tray doesn't require any spacers. I used the washers/spacers in the main stud kit as a buffer for the windage tray nuts (to keep the serrated flange nuts from tearing up the tray). Using some "mach"-up washers I found that were the same thickness as the compressed gaskets, pickup-to-pan clearance is right within spec.
silverbullitLS1
02-14-2012, 09:17 PM
I'll have to check that out seems like a easier and safer rout to go with. I did use my old oil pan gasket to get the clearance for the pick up tube so I should be good there, but that windage tray is really getting to me.
cwalsh
02-17-2012, 04:14 PM
Thats one clean oil pan! Is it new? How much was the windage tray?
Chris
BLOWNBLUEZ06
02-18-2012, 10:01 AM
I did what was in the pic. I carefully "massaged" the pickup tube and used a .250" metal plate across the base of the pickup to verify my desired clearance. I've done it many times with stroker motors and stock trays using the washers.
RLS!
02-18-2012, 10:56 PM
Chris
New pan...yessir. I sourced it from ebay. My C5 came with the one-piece pan and I wanted to keep it with the engine that came with the car.
I can't recall what I paid for the tray, but I see it goes for around $80 now.
eric1h
04-18-2012, 01:28 PM
hey, quick bump, where did you order the MAST windage tray from?
RLS!
04-21-2012, 06:52 AM
Byun Speed aka Colorado Speed... (site sponsor)
http://www.coloradospeed.com/index.php?main_page=product_info&cPath=2902_714_1201&products_id=14987
VINCE
04-21-2012, 09:22 PM
I am running a LS2 oil pan..
