Tools & Fabrication - What lift to buy
3rdCoastPowerSports
02-06-2012, 04:14 PM
plan on opening a little shop here in the next few months. what lift should i buy? I will be working on anything that is LS based, mostly corvettes, trans am, gto and camaro
RGKSR
02-07-2012, 02:45 PM
I've got a Mohawk in my home garage. Works great and is American made!
Bob K.
Kory 88Iroc Lt1
03-05-2012, 10:17 PM
I have a benwil 2 post 7k lb in my garage. It origionally came from a gm dealer. Bought it used on craigs list for 1200. I have seen a couple since then for simular prices.
Definately a worthwile upgrade.
Good luck with your venture. I'd do the same if I thought I'd have enough work to keep the doors open.
Kory
ragtopz28
03-06-2012, 08:28 AM
10,000 lb ROTARY 2 post
:D
3rdCoastPowerSports
03-10-2012, 12:23 AM
Kory
Anything in particular that I should look for when purchasing a used lift?
Kory 88Iroc Lt1
03-10-2012, 09:37 AM
Make sure the cables are in good shape.(not frayed ) and have a close look at the pump and motor. There are companys that sell parts for almost any lift ever made, but the parts add up quick. The pump on mine was replaced a short time before I bought it. I believe that the replacement was around 300.
Hope this helps.
Kory
onebaddmax
04-05-2012, 05:45 AM
I've got a Bendpak asymmetric 10k pound 2 post. I love the Asymmetric for the ease of getting in and out of the vehicle due to being able to open the doors farther without hitting the posts. I got mine off ebay for 1200 bucks when it was 6 months old.
Not A Z
04-19-2012, 10:56 AM
This! If you can find one or can pay for the upgrade this is the way to go.
I have a 2 post Challenger CL10 (10,000 lbs) lift I got from the closing GM plant for $1000. One of the best purchases I have ever made.
Setup on them is pretty easy. Hardest part is standing up the towers. We used 2 cherry pickers to do this safely. Once they are up they are pretty sturdy and you can move them around. Mine has the cables that go over the top of the hoist so there is a plate up there to set distance between the towers. Once you had this plate bolted up the spacing set itself. Then we drilled the holes in the concrete and bolted it down. :nod:
Z284U2TRY
04-19-2012, 12:17 PM
I have a atlas from geg smith in my home garage and its a great tool. Only problem was I didnt get one sooner.
jetsbaby
04-22-2012, 12:44 PM
I would also like to buy a four post lift soon..But most of the lifts are made in China today and most US lift companies have gone out of business..I heard that Bendpak now is even made in China..I am sorry but I don't trust the Chinese welding on stuff that is holding 3000 plus pounds over my head..:(
TOOFASTMONTE
04-26-2012, 12:08 PM
Rotary or Mohawk
Zmg00camaross
04-26-2012, 12:47 PM
:D
Yup. :burn:
3rdCoastPowerSports
04-28-2012, 02:19 PM
Rotary seems to be the most recommended and most common used professionally (around here at least)
TheLS1Lover
04-28-2012, 02:25 PM
:D
x2.
These are what we have at tech and I freaking love them.
35th SS
04-28-2012, 02:28 PM
benwil 2 post at 7k capacity bought it used for 1400bux installed.buy american made.
My1st4thgen
05-26-2012, 11:17 AM
challenger all the way. versametrical
