armyboyatc
02-06-2012, 05:00 PM
A buddy of mine is putting my cage in and I thought I would share it with you guys and see what yall thought. Let me know what you think.
Pics and info are quoted from a local forum.
First I took some measurements and bent up a template from 3/8 tubing. I find this to be the easiest way to figure the bend angles off of. There are 4 bends to each side of the arc, one of which I did not template for at the roof line.
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar.jpg
Then out with the plasma to put a couple holes through the floor. - Not necessary for just a 6 or 8 point roll bar, but I'm going to tie it to a rear cross-member thus allowing for easy upgrade(25.x) later on down the road.
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/rollbar1.jpg
from underneath -
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar2.jpg
Now, my main hoop. Looks kinda funky outside the car, but I think fitment is about as good as it gets.
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/RollBar3.jpg
Slipped in/through the floor -
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar4.jpg
...and up into place -
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar5.jpg
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar6.jpg
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar7.jpg
Rear down-legs, stuck through the stock rear speaker holes -
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar8.jpg
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar9.jpg
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar10.jpg
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar11.jpg
Then on to the seat mounts for now. I prefer to know the driver positioning before running the cross tube or the door bars, thus to maximize function & side entry opening.
Simple manual slider bolted to the seat -
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar12.jpg
Simple mounting system. 5/8" box tubing & 1/8 plates. These rest on the rocker sill thus are roughly 2" above the floor -
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar13.jpg
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar14.jpg
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/rollbar15.jpg
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar16.jpg
No need for a slider on the passenger's side -
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar17.jpg
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar18.jpg
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar19.jpg
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar20.jpg
http://i431.photobucket.com/albums/qq31/ArmyBoyATC/Rollbar21.jpg
What y'all think so far? - I'm pretty happy with the fitment of everything. The main hoop took some time to get to my liking, but it's tucked as tight as reasonably possible.
Next will be to put the cross tube in the main hoop, bracket the seat backs to it(with a slider mount for the drivers') and tabs for the harnesses. Then have to get the door cards on to fit the door bars around.
----- End quote-----
What do you guys think? My main concern is the seat brackets. If you know a lot about passing tech ahem ahem JL ws6 let me know what you think of it.
Enjoy the pics and let me know what you think!
Thanks fellas:chug:
from underneath -
Thanks fellas:chug:
