How to tell if my car is on SD or MAF tune??
Hey guy's, I just sold my procharger kit to another tech member a couple weeks ago. Since then I have been switching everything back on my car to NA untill I get my forged engine put in about 2 weeks from now.I'm still using the car as my DD and was hoping I could still romp on my car (smash the gas), but I dont rember if I got my car tuned on speed density or if it's still MAF. I would'nt dare to floor it on a SD tune, but I know MAF will compensate for what ever (I think lol).I know that when I unplg my MAF sensor it shuts the car off...sooo not sure what that means lol. Anybudy know a good way to tell if I'm SD of MAF?..Thanks ahead for any help.
anyone else got anymore input on this...seems like I'm leaing more towards the thought that it's MAF tune still. I just want to make sure before I floor it and mess something up
Get it refined but I'm pretty sure if Ur car dies when u unplug the maf its probaly on the maf tune. Bein as SD has no maf so that wouldn't really make any sense it shouldn't even tell if the maf is plugged in on SD I would think but don't quote me on it I'm just giving it a educated guess but am curious as well.
but if it was MAF then it shoud be able to compensate for the amount of air it now recieves correct?? as well as adjust timing on it's own??.I have put it up to 75% throttle so far and everything seemed fine. I do not want to hurt it but I'd hate to take it to get retuned for only 2 more weeks of driving with this motor in it. It's getting a LME Forged 347 and a turbo kit put on it soon so I need to save my money to make this swap happen. I just would like to still have a lil fun with my car in the meantime. The engine run's great at only 64k miles and I do plan to seel it once it's out the car. I'd really rather not hurt it so I'm not gona floor it until I found out more about this tune thing.
have a wideband? I mean if it is tuned for boost it will run stupid rich at WOT without the boost, but idk about the MAF compensating that much. Good thing is that you shouldnt have too much timing in it. Just be patient and take it easy till you get the new setup
Just stop driving it until you get your new motor in and get it tuned.
From my understanding an SD tune just turns the MAF reading off in the pcm so that it can be removed from the intake tract; I don't think it would recognize the MAF being plugged in or not as its turned off in the PCM.
Car runs just FINE dude...I been driving it back and forth to work for the past 2 days ,and me and the wife both have a job ,and we got only 2 vehicles so I'ma drive it. I get in, turn the key and it bust right off and idles as smooth as your mom (jk jk). Even under part acceleration the car sounds great and runs perfect.. I could've sworn I heard before that the MAF (or maybe it was the knock sensors) can pull or add a lil bit of timing if the MAF senses the need..this is LS1Tech and it's the place to ask those questions that's why I asked. I got 60lb injectors on the car still and I dont' plan on flooring it while this engine is still in it cause I want to sell it. It's a great engine and in essence is running exactly the same as it was with the procharger on it. Only difference is at WOT my car was seeing 6lbs of boost. It makes perfect sense that if you keep it under 70% throttle ( I got an A4 btw) then it will be just fine till i pull it out not this weekend but the next.
Trunion King
Knock sensors will pull the timing not the MAF.
MAF will measure the air that goes in via Hz then sends that signal to the PCM so it will feed X amount of fuel to your motor...
Since you motor is on boost timing, the timing will be already low vs N/A tune and your AFR setting is going to be really FAT on fuel.
