sho-me speed
02-06-2012, 09:24 PM
We are a WD dealer for Neal Chance converters and we thought it was time to give some of our customers a great deal on one of the best converters in the business. Call for Pricing on the Converter you are interested in.
Prices start at $429
Street Performance Converter
NCRC Street Performance Converters are ideal for use behind a High Performance Muscle Car or Truck that is intended primarily for street duty.
•Furnace Brazed and Heli-Arc Welded Fins
•Cast Aluminum Stator
•Anti Balloning Plate Available
•Torrington Roller Thrust Bearings
•Hardened and Ground Pump Hub
•Billet Steel / Fabricated Front Cover
•Conventional Spring and Roller Sprag
•Dynamic Hi-Speed Neutral Balanced
•Custom Fin Angle for your application
Unlike other converter companies that sell an off the shelf, one size fits all street performance converter, NCRC Street Performance Converters are 100%custom built for your application so that we can carefully match the stall speed to what your vehicle needs.
Available 9.5" Diameter Turbo Spline for GM TH350/TH400 or Glide with Turbo Input Shaft. All NCRC Street Performance Converters are covered by the famous NCRC "If you can break it, we'll fix it" 1 year warranty. Lead Time after order placement is typically 1 week.
WELD UP RACING CONVERTERS
Found in more record setting race cars than any other brand!
NCRC's Weld Up Racing Converters set the standard for product quality and performance in the racing industry. You can't buy a stronger or more well built converter, anywhere, for any price.
•100% Furnace Brazed
•100% Completely Heli-Arc Welded Fins
•Anti-Balloning Cover
•NCRC Mechanical Diode
•Stators available in Fabricated Steel, CNC Billet Steel or CNC Billet Aluminum
•Custom Fin Angles
•Heavy Duty Thrust Bearings
•Billet Steel Front Cover
No other company offers the level of detail that NCRC does in their racing converters. For example, EACH AND EVERY fin in the converter has Seven Full Welds on it - other companies only partially weld their fins... even on their highest dollar converters!
Available in 8", 9" and 10" models for almost any configuration and custom stall speed desired. NCRC has drive options to fit ANY racing transmission on the market today - including many "yet to be released" drives.
All NCRC Racing Converters are covered by the famous NCRC "If you can break it, we'll fix it" 1 year warranty. Lead Time after order placement is typically 1 week.
BOLT TOGETHER RACING CONVERTERS
Make changes to your setup at the track or in the garage!
The Standard of Excellence in Converter Design and Quality
NCRC introduced the Worlds First Bolt Together Torque Converter over 20 years ago, and we've continued to refine it making it stronger and more efficient every year!
By making the Pump and Drive Covers removable, you can make changes to your converter at home.
Want to change the stator at the track? You can! Smoke the clutches in your transmission? Clean it out at home without shipping it back!
•NCRC Extreme Duty Mechanical Diode
•Custom Fin Angles
•Optional CNC Machined Billet Aluminum Drive Cover for reduced rotating weight
Available in 8", 9" and 10" models in many different configurations and stall speeds including an Aluminum Drive Cover Option. NCRC has drive options to fit ANY racing transmission on the market today - including many "yet to be released" drives.
BILLET RACING CONVERTERS
The lightest & most efficient converter available on Earth!
100% Billet Aluminum
Bolt Together Racing Converters
ONLY Available at NCRC!
The very latest in Racing Torque Converter Technology. 6 lbs lighter than our Steel/Aluminum Bolt Together, the Full Billet Converter also offers State of the Art 5 Axis CNC Precision Machined Pump Fins and Stators for the Ultimate in Efficiency and Power Transfer.
•5 Axis CNC Machined Body and Fins
•NCRC Extreme Duty Monster Mechanical Diode
•Custom 5 Axis CNC Machined Fins increase efficiency.
•Optional CNC Machined Billet Titanium Drive Cover
No other company offers the level of detail that NCRC achieves in their racing converters. For example, EACH AND EVERY fin in this converter is fully CNC machined which gives you outstanding repeatability and consistant fin profiles, a feature not available on any other converter.
Available in 8", 9" and 10" models in many different configurations and stall speeds. NCRC has drive options to fit ANY racing transmission on the market today - including many "yet to be released" drives.
How much performance improvement will you see? Of course a lot depends on what you're replacing. This converter may be as much as 17 lbs lighter than a competing product, and it's 6 lbs lighter than the NCRC steel/aluminum bolt together model. That's a lot of rotating weight!! We are getting feedback from some saying it's worth around a tenth in the 60' and more in the quarter! Of course as with any racing part, you results may vary but we're hearing of some serious improvements - ask around!
•Custom Fin Angles
•Custom Fin Angles
