Forced Induction - Desired sleeve thickness for F/I build?
My6speedZ
02-06-2012, 09:41 PM
If you building a motor with low compression for a supercharger or turbocharger, what is the minimum you would want to go on sleeve thickness on an aluminum block?
Does anyone know a reference chart that has the numbers for the different blocks.
I am wondering just how weak the LS7 sleeves are as I was talking about it in another thread.
I know re-sleeves often boast more thickness at larger bores than stock with smaller bores. Just trying to get an idea of where they draw the line between just a re-hone or needing to be sleeved.
9sectruck
02-06-2012, 10:11 PM
on a factory sleeve no more the .0010 over the stock size for a power adder.
My6speedZ
02-06-2012, 11:29 PM
What is it that makes the LS7 liners weaker? are they thinner overall dues to the bore requirements? If they are using the same sleeves for all the gen4 blocks?
So.jerZ-28
02-06-2012, 11:31 PM
I disagree... Certain blocks will hold more power without egg'n or twisting the block, such as a iron 5.3 or 6.0 block.
EVERY BLOCK should be sonic tested before boring and consult with the engine builder on how much can safely be bored to withstand your hp goals!!!
9sectruck
02-07-2012, 08:05 AM
as op stated this is for a aluminum block not cast iron.
thats why I said .0010 on a stock sleeve, most cast iron block that I have seen dont have sleeves in less they really got f---- up
9sectruck
02-07-2012, 08:08 AM
on your question I do think the sleeves are to thin from the start for big power, but never really had a chance to mic a ls7 sleeve.
blue00ZZleeper
02-07-2012, 09:57 AM
From what I've heard the LS7's use a different style "Grey" iron liner. I believe that their more brittle then other liners, but were a good bang for the buck for a stock LS7. Most people looking for big power endup resleeving them. I'm sitting in the same boat right now, doing homework for a new motor. I would look into a LS3 block. On their stock bore, they seem to be pretty decent and with a slight increase in stroke, you can get up to a 427ci. I'm leaning more towards a LSX block but I'm a little concerned about core shift.
SirNemesis
02-07-2012, 05:44 PM
I'm running 30thou oversize on my LS2 block, no issues so far.
My6speedZ
02-07-2012, 08:27 PM
Ok, i was wondering if the same sleeves were used in all the blocks or if they were different.
For me personally if I ever go Procharged (thrown the idea around a few times) I would just go with a set-up almost identical to yours. 390ci iron with an F1
I was just curious where there is alot of talk about ls7 popping under little boost.
Yea I know you can go 30 over for n/a builds. With the extra heat, wouldn't you want to keep it at no more than 10 thousands over like the other guy said?
Whats the biggest enemy for the cylinder walls in a nitrous or f/i application? The additional heat created or something else?
SirNemesis
02-07-2012, 08:37 PM
Mines turbo. 390ci AES rotating assembly with a Borg Warner S400SX3 (S475).
WS6HUMMER
02-07-2012, 10:23 PM
I'm interested to know if a aluminum 5.3 punched out to a 5.7 will hold any boosted power.
My6speedZ
02-08-2012, 11:30 PM
I know the 5.3'd are a prime candidate for a re-sleeve.
They look to have pretty thick sleeves (the al 5.3) from the factory. I will see if I can get my partner to mic one of the ones we have laying around.
WS6HUMMER
02-09-2012, 09:21 AM
What about when punched out to a 5.7? I think they have to be bored a lot, lik .9xx something.
blue00ZZleeper
02-09-2012, 11:09 AM
I'm pretty sure a couple of guys have taken them out to a 3.905" bore. Even more have left it in stock trim keeping the cyl walls stronger and just ran a lot more boost.
We plan to just leave it a 5.3 in favor of much stronger cylinder walls!
98BLOWNZ28
02-09-2012, 11:38 AM
I don't quite understand why people go with 370s. All I hear is they are a good balance in cubes and perfect for a power adder, but I think it's kinda stupid to bore it .030 over from say and ls2/lq block which are 364 stock. So why make a 370 with thinner cylinder walls, just to gain 6 cubes? Lol.
LS1NOVA
02-09-2012, 12:00 PM
Because most core blocks need an overbore and .030 pistons are readily available.
blue00ZZleeper
02-09-2012, 12:06 PM
When you bore it out, you facilitate less valve shrouding with heads that use larger valves. The intake valve ends up "Shrouding" the airflow on a smaller bore motor. Boring it out, allows more room for the air to enter without it "stacking" up. I use stage 3 LS6 heads with a 2.08 intake valve and I wanted the best possible airflow I could get.
My6speedZ
02-09-2012, 11:49 PM
Good to know.
I believe on the boost 5.3 AES sells they are running a 3.850 bore.
chuntington101
02-10-2012, 06:57 AM
Didn't Firehawk run at around 1800bhp on stock sleaves in a LS2?....
slow67
02-10-2012, 12:01 PM
http://ls1tech.com/forums/forced-induction/1375346-aes-boost-5-3-shortblock-2599-a.html
The Alchemist
02-10-2012, 09:20 PM
So a stock ls1 taken from 3.898 to 3.905 is 0.007", is that an issue?
My6speedZ
02-13-2012, 02:13 AM
See I'm wondering the same thing, I'm at a 3.905 right now... Wanting to go boosted next with a D1.
Mahle makes 3.908 pistons looking for 650-700.
blue00ZZleeper
02-13-2012, 08:58 AM
Usually a 3.905" bore is decent on strength and can handle a fair amount. I wouldn't however go with a 3.908" bore. Remember when running boost, your cyl pressures go up quite a bit....In my personal opinion I wouldn't chance it. There are way to many other options available to push your luck with an overbored motor. Just get another stock block and use it on a 3.905" bore....Is it worth chancing? lol
killernoodle
02-13-2012, 10:23 AM
.003 over 3.905 isn't exactly a lot of material. 3.908 should be fine. Usually, you'll take an old ls1 and hone it to 3.903 or 3.905 for new pistons. If you have to oversize again, you can still do 3.908 safely. At that point, you've gone to .010 over and shouldn't oversize again.
My6speedZ
02-15-2012, 01:56 AM
If I end up getting another block I will just go iron 370.
Been looking at these DIY truck manifold set-up's doesn't look that difficult and seems to end up being cheaper. May end up looking into something like that.
