Drag Racing Tech - Fitting a 325/50/15 successfully ? and options for rear coilovers?
00blacka4
02-07-2012, 10:44 AM
are there stock mounting rear coilovers? and what do i have to do besides roll the fenders to fit my 325/50/15 mickeys successfully ? alot of BFH mod?
5.3LJimmy
02-07-2012, 01:40 PM
I had to cut off the bump stop and the mounting area. I would also suggest you procure at least a 10lb hammer to help speed up the "fitment" process.
TurboStangJON
02-07-2012, 03:39 PM
Cut off a significant amount of the bumpstop then use a hammer to massage the fenderwell inward. After a lot of work I still had issues with my control arms hitting the tires during turns. Also, I couldn't lower the car any so it was stuck in 4x4 status. Any reason for such a large tire? 275's won't work?
00blacka4
02-07-2012, 04:51 PM
i have a light car, and race on the street alot, will be adding a significant amount of power and i want to do everything i can to hook
00blacka4
02-07-2012, 04:53 PM
im also ditching the lightweight battary and going with an optima in the trunk to help...and getting my car scalled and setup so hopefully hooking wont be a problem
