View Full Version : Can anyone ID this cam? cc p7088-09
snipes
02-07-2012, 03:38 PM
http://i9.photobucket.com/albums/a57/twin051302/photobucket-38991-1328649116754.jpg
Trying to see if this suitable for my budget LS1 build and dont have any info to go on:bang:
snipes
07-29-2014, 07:54 PM
The other number thats stamped is 2870H:confused:
snipes
07-30-2014, 02:18 PM
Comp Cams got back to me, here is what they sent:
Serial # P 7088-09 Spec Card# 15591509
Part # 54-000-11 CAMSHAFT, LS1 CHEVY LS1/GEN III '97-UP
Core C54-11II CAMSHAFT BLANK, LS1 1997 UP 5.7 CORVETTE
Grind # LS1 13018R/ 13020R HR12
DURATION @ .050 INTAKE 231 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 239 INTAKE 1.70
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3630 EXHAUST 1.70
VALVE LIFT INTAKE .617 LOBE LIFT EXHAUST .3670
VALVE LIFT EXHAUST .623 LOBE SEPARATION 112.0
DURATION .006 INTAKE C/L 112.0
TAPPET LIFT INTAKE 281 CAM ADVANCE 0
TAPPET LIFT EXHAUST 289 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 3 JOURNAL DIAMETER STD 2.165
VALVE OPEN EXHAUST 51 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 47 DEPARTMENT P
VALVE CLOSED EXHAUST 7 SPC INSTR FOR CUSTOMER
What do you guys think for a mild N/A LS1 build using this cam?
