Info For Best Gears
Info For Best Gears
Currently looking for an improvement in my gear situation. Right now riding with the stock 3.23s....thinking about 4.10s but the car is however driven roughly 2-3 days a week in the summer depending on weather conditions. School is 10 miles away and work is 5 miles away, would 4.10s kill my mpgs with the A4? The camaro does see quite a bit of drag strip use.
I assume your still running a 26" tire?? That and with an A4 I would say 3.73,but then again I am biased!! An yes your fuel mileage will suffer from 4.10s..not saying it won't a little bit with 3.73s but not that much!!
Yea 26'' tire, would it wake it up in the 1/4 mile though? The car does not have to be driven alot but i would like to wake it up bc it seems sluggish out of the hole.
Yes 3.73s will definitely wake it up with that size tire!! Unless you have a big cam I think 4.10s in an A4 is alittle to much gear..but everybody has different preferences..read through the gears an axles section,there's a lot of threads from this sort of stuff in there!!
I run 4.10's in my 94. Not in anyway a daily driver. That matched to 3600 convter is a nice combo. If I was running it everyday up and down the interstate I'd keep the 3.23's. There's money to be spent else where. 4.10's in a 10 bolt are some weak gears. It really is a preference.
Like i said the car is mostly for fun, i have a beater that i can putz around town in. Im just looking for the best rear gear ratio that will wake up a bolt on only A4.
I went from 2.73s to 3.73s and that was a nice difference and must for a shitty stock gear. If I were you and had stock 3.23s. I either step up to 4.10s otherwise your not going to feel that much of a difference over stock, or keep the gears and get a converter.3.23s to 3.73s is not a big difference at all.... If you get 3.73s I bet you'll be like "oh, not much of a difference except the wasted $.....****..."
