Procharger 6.2 silverado
I'm putting a p1sc kit on my 6.2
I have a UDP on now should I put the stock crank pulley back on?
And I'm wanting to add few more lbs of boost which size pulley should I put on the head unit?
Should I run a crank pin also?
Truck makes 377rwhp 396tq
Which without the vararam and UDP it will b a lil less
What kind of power will it make? 550-570 rwhp?
Thanks
Any other advise is appreciated
Thanks
LS1Tech Sponsor
http://shop.brutespeed.com/ATI-3GKMM...-3GKMM-004.htm
Here is the crank pinning kit. If you want a copy of the ProCharger installation instructions, send me an e-mail to brutespeed@gmail.com and let me know what kind of vehicle the installation instructions need to be for.
How much boost the blower can produce depends on many variables.
* Cubic inch. The larger the engine the less boost it will make with a supercharger.
* Headers and exhaust. A better flowing system will produce less boost, requires a smaller pulley to regain the loss in boost. Ultimately though, more power will be gained.
* Camshaft and heads. A camshaft with some overlap will leak out some boost through the valves. Better flowing heads react a lot like a better flowing exhaust system.
* Altitude. Elevation plays a big part in how much boost is produced. Those people living in the higher elevations have to spin the blower harder to see boost.
* Condition of engine. An engine with real good sealing rings will ultimately produce more boost than one with worn rings.
* Rpm. An engine that is spun up higher in the rpm range will normally produce more boost.
I sell the blower pulleys at this link.
http://shop.brutespeed.com/ATI-DPxxx...-ATI-DPxxx.htm
In the notes section of the order form, you can put down what your combination is based off the info I gave you above, so we can spec out the right size pulley for you.
8 psi will generally give you a 140 rwhp increase, a ProCharger makes a huge night and day difference in the power! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Bob,
Thanks for the great info
I called procharger they gave me a 3.7 pulley
And a pin kit
Damn I forgot u carry procharger ... I'll call u for the rest of my needs
My truck has a 6.2 with kooks, catted y pipe and stock cat back
And a vmax z06 tb
Mike norris will be tuning it
I do need to order plugs I forget what the manual recommended.
I think tr6s
Thanks
Jason
LS1Tech Sponsor
Bob,
And a pin kit
And a vmax z06 tb
I think tr6s
Thanks
Jason
And a pin kit
And a vmax z06 tb
I think tr6s
Thanks
Jason
Not a problem. I'd get the NGK TR6 pn# 4177 plugs, and gap them at .032 to .035. Bob
__________________
Got the injectors in
Head unit and intercooler mounted
Seems like a real easy install
Hardest part looks to b putting stock crank pulley back on
Maybe will have it running by tonight.
Got it put together
Started rite up
Let it idle for few mins
Did this 3 times
Then cracked throttle ,... Then died
Now it starts and dies
Still need a tune and install boost a pump
I hope this is y it won't stay running now
Started rite up
Did this 3 times
I hope u put a tune in it at least for the bigger injectors before running it. Otherwise u can wash down the cylinder walls. Good luck with it and I can't wait to see what it is like when it is finished.
