possible check engine light?
Old 02-07-2012, 10:46 PM
99camaro5.7's Avatar
Question possible check engine light?
Ok I wasn't sure where to post this so ill post it here Haha. I used to be a mechanic and ive seen codes set for the ac compressor having a high resistance usually because its unplugged. I'm planning on removing all of the ac in my 99 z28 and I'm just wondering if I'm going to set any codes. I need to pass inspection and the last thing I need is a fail because the check engine light is on. Anyone please help!
Old 02-08-2012, 11:53 AM
flame's Avatar
It will set a code or 2 but should not turn the light on. You could leave the pressure sensor plugged in to complete the circuit and I don't think it will set codes.
Old 02-08-2012, 02:50 PM
That's good thanks alot
