Help Diagnosing Rear End Noise
Ever since I got my car (back in 06) its had a definite noise coming from the rear. Ive finally just gotten sick of it and am trying to pinpoint it to fix. It is loud enough that you have to speak almost at a yelling level to hear over it and is even louder than my duals. It is a continuous droning noise that sounds like a bad tire or extremely loud road noise. It is not a tire because I just got new tires on all 4 corners and it didnt do anything. The noise is completely speed dependent and has no real change from being under load or accelerating/decelerating. It sounds like it is coming from the drivers side rear, but is hard to pinpoint. Tight turns in either direction change the noise, but dont necessarily make it better or worse. You cant hear it from outside the car from what I have been told.
Tomorrow I plan to jack the car up and spin the rear by hand to see if I can hear anything. I will also get videos of inside the car and out. Are there any other tests I can do to try to pinpoint the problem? Does anyone have an idea from the info given? Thanks a lot.
I have the same problem. Thought it was the axle bearings (since it seems like I can here it more in the right rear tire area. So I changed the axle bearings last night. Axles looked fine when I took them out. Now with the new bearings it sounds...............THE SAME!
Did you ever find out what the problem was??
Noises from rear ends come from two things, bearings and the ring and pinion gears. 10 bolts have some problems with the bearings on the pinion gear. Unfortunately these are the hardest things to get to and a lot of trouble to look at. Look at everything else first as they are on the way to the pinion bearings anyway. The first things to remove are the axles, look at the axle bearings. Then the carrier bearings and ring gear. If everything looks good you have to pull the pinion and look at it and its bearings. Not an easy job. What you can do is remove the back cover and look for signs of metal particles. That would indicate something is going away.
If you're inexperienced at this, have a real rear end shop do it. Not a general auto repair place.
Al 95 Z28
Al 95 Z28
Moderator
I have a noise which may be similar, if not as loud. It
is "light metallic", follows road speed but not accel /
decel or lateral load.
To me it sounds sort of like the pads are dragging on
the rotor and ringing it like a champagne glass. Which
if true would probably want brake sliders greased.
My 10 bolt sounded like that, it turned out the carrier was completely cracked around the driver side axle where it meets the carrier. the only thing holding together was the bearings. I didnt even waste time with another 10 bolt and ordered a S60.
Well I guess I will be tearing the axle apart once I get my jeep back on the road. I found this article from GMHTP about refreshing a 10 bolt.
http://www.gmhightechperformance.com...l/viewall.html
Everything seems pretty straight forward. I plan on doing at least the axle seals/bearings and the carrier bearings. Is there anything else I should check while I am in there?
I have a 2000 firebird..had it in the shop to have the rear end rebulit and it is still making a high pitched noise....shop says they dont know what else to do except to put a new or used housing...does anyone have any suggestions on what i should do? Is it worth it? Will that solve the problem?
