Drag Racing Tech - ac delete please help!
99camaro5.7
02-08-2012, 03:30 PM
Ok I haven't found the answers I've been looking for so please someone help! I want to delete all the ac but I still want to keep the heat in my car. I found a really nice hvac delete panel from umi performance but I see that the heater core hoses run through the hvac unit. Is there any way that I could cut the ac crap out and leave the heater core and cut holes in the delete panel for the heater hoses? Or is there a better way all together? I really don't want any ac in my car what so ever I'm looking to cut weight and free up space in the engine bay, thanks.
theguyulove2hate
02-08-2012, 03:55 PM
Summit sells a light weight defroster. I don't know the part number but I'm sure someone will jump in with it. Just mount it in, cut some holes in the block off plate and run your lines.
armyboyatc
02-08-2012, 04:43 PM
Ask studderin. He has a bad ass setup. Seems to me that you can mount a blower motor under the center of the dash under the defrost vents,build a plastic box around it and then mount a heater core on top of it and run the lines through the HVAC delete panel. Just drill some holes through it and use a A/N fitting setup to make it look clean.
transam69230
02-08-2012, 04:52 PM
I deleted all the factory A/C stuff out of my car when I had the motor out last time. I used a BMR panel with two holes cut into for the heater lines. I used the factory lines that run from the radiator into the car for heat.
I used a dremel to make it smooth so the plate bolted down nicely against the firewall. Then I took some 3/8 thick (can't remember size) foam tape from menards and put that behind the plate to keep the air in. Heat works great, and haven't had any problems.
Heyfred
02-08-2012, 06:35 PM
Here is how I did mine. Engine out of the car.
http://www.ls1tech.com/forums/drag-racing-tech/1054626-c-delete.html
99french
02-08-2012, 07:21 PM
I did the summit heater and wired it into my factory controls. I used the smaller of the two that summit offered. And i used a piece of diamond plate bought from menards and just invested time and drilled my own holes.
camaroz28lt1at
02-08-2012, 10:12 PM
Thats also how I did mine. Worked great!
soundengineer
02-09-2012, 11:20 AM
HVAC Delete Plate From AEICNC (www.aeicnc.com)
Flex-a-Lite Mojave Heater....
Dont mind my mess in these pictures... this was in the middle of a complete rewire...
but it shows my Heater off well..
I went for the toes instead of the glass...defroster isnt really all that necessary..LOL
http://i1107.photobucket.com/albums/h384/soundtechscott/2001%20Chevy%20Camaro/Mojave%20Heater%20Install/IMAG0126.jpg
http://i1107.photobucket.com/albums/h384/soundtechscott/2001%20Chevy%20Camaro/Mojave%20Heater%20Install/IMAG0129.jpg
djfury05
02-09-2012, 05:08 PM
I'm guessing this guy wants to keep the stock duct work and heater core. Therefore cutting the holes for the hoses at the top of the HVAC delete plate is your best bet.
99camaro5.7
02-09-2012, 05:58 PM
Yea I'd like to keep the duct work and heater core where it is I just want the ac crap gone. So cutting the 2 holes for the heater core hoses out of the hvac delete panel would allow it to bolt up?
transam69230
02-09-2012, 06:06 PM
Yes it will!
99camaro5.7
02-09-2012, 06:25 PM
You wouldn't happen to have any pictures would you?
99camaro5.7
02-09-2012, 06:47 PM
One last question, so does that hvac unit unbolt or does it have to be cut out. I see a few guys say they sand it smooth so the panel will bolt on
djfury05
02-09-2012, 08:58 PM
The portion in the engine bay is bolted in to the HVAC assembly from the engine bay side as well as from inside the cabin. Inside the cabin there are 4 bolts near the panel area, and 1 in the middle of the engine bay on the firewall below the intake. 6 on the engine bay side. You will have to pull the dash to get the entire assembly out otherwise you'll have to break apart the box from the engine bay side. I had my motor out and took a hammer to the box and got it out in 5 mins no problem. Then you have to notch the internal panel near the blower door so heat can pass through to the duct work.
Here is where I notched mine at. You will have to make a cover panel here where the open space leads into the dash area. I sealed mine with RTV sealant and used some screws to secure it.
http://i268.photobucket.com/albums/jj19/djfury05/DSC_0014800x531.jpg
Here is where I made the panel and RTV sealant was used.
http://i268.photobucket.com/albums/jj19/djfury05/DSC_0020800x531.jpg
Z28/2002
02-09-2012, 09:17 PM
I did mine like djfury05
99camaro5.7
02-10-2012, 07:11 AM
After I cut the holes out for the heater core hoses what should I used to seal around the hoses? Would rtv work ok, those hoses will get pretty hot I just don't want to use anything that could potentially cause a fire
djfury05
02-10-2012, 07:16 AM
There is a foam insulator type thing over the pipes that you will see when you get the box off.. I would move it to right up towardcs your panel over the ridges of the pipes. You will see what I'm talking about once you see it in person.
99camaro5.7
02-10-2012, 09:51 AM
Ok, thanks a lot everyone for the help!
2002camaroSS
02-14-2012, 08:40 PM
I can speak on transam69230's behalf the heat in his car will make you sweat lol. Just do the plate with the holes cut out for the stock lines and you will be golden! Plus it makes it very easy to do plugs on that side of the motor also!
camaro keith
02-22-2012, 05:30 PM
what radiator did you guys use afterwards
soundengineer
02-22-2012, 05:31 PM
Stock Radiator...
camaro keith
02-22-2012, 07:11 PM
Stock Radiator...
maybe i am missing something or not understanding how are you using the stock radiator if you are deleting all the lines?
soundengineer
02-22-2012, 07:15 PM
you still need the radiator to cool the engine....
and your AC delete doesnt delete the heater...
if you do a complete HVAC delete, then you can dump the 2 smaller hoses that come off the lower side of the Water Pump
or you can take those 2 lines into the cab and into a heater core/fan combo..
I chose to keep the heater...Mojave Heater by Flexalite...still uses the coolant just like the stock heater core does...except this is more efficient, smaller, and way lighter.
either way... your radiator is not directly connected to the heater/ac stuff...
the heater is independent and comes off of the water pump
if you delete it entirely, you can just cap off and clamp those two ports on the water pump... I ran mine capped off for a few weeks until I decided to get the Mojave Heater.
69gto96z
02-22-2012, 07:27 PM
Yes you can keep heat. I would go and get a piece of aluminum and make your own panel, it will end up way cheaper. Here is how I did mine, with the engine in the car. I also kept the vacuum line so I can still switch it between feet, face, and defrost.
http://i52.photobucket.com/albums/g14/69gto96z/IMAG0412.jpg
http://i52.photobucket.com/albums/g14/69gto96z/IMAG0414.jpg
http://i52.photobucket.com/albums/g14/69gto96z/IMAG0419.jpg
http://i52.photobucket.com/albums/g14/69gto96z/processed_image.png
soundengineer
02-22-2012, 07:52 PM
My version of the same thing..
http://i1107.photobucket.com/albums/h384/soundtechscott/2001%20Chevy%20Camaro/Mojave%20Heater%20Install/IMAG0362.jpg
http://i1107.photobucket.com/albums/h384/soundtechscott/2001%20Chevy%20Camaro/Mojave%20Heater%20Install/IMAG0361.jpg
http://i1107.photobucket.com/albums/h384/soundtechscott/2001%20Chevy%20Camaro/Mojave%20Heater%20Install/IMAG0364.jpg
camaro keith
02-23-2012, 04:42 PM
any suggestions to make it a little easier on myself when doing this with the engine still in the car?
