welldonecj7
02-09-2012, 12:47 AM
I have a vortec gmpp crate motor that had an oil leak on the back of the intake manifold. I bought the fel pro 1255 gasket however when took it off it had a newer style gm gasket. after researching online I have gotten mixed reviews as to which style is better so thought i would ask and see if you guy have experiance with this?
welldonecj7
02-09-2012, 06:04 PM
Anyone used either style?
1dirtybird
02-09-2012, 08:07 PM
I use the factory plastic/ o-ring style with arp bolts torqued to factory spec 12 or 18 ftlbs i think.
18ft lbs max! use the right stuff silicone instead of the rubber end seals and a very small amount around the coolant ports, i've used all available vortec gaskets, for fuel injected R-code engines the updated felpro works good, for carb'd applications i like professional products gaskets, if your intake was ever overtorqued its possible its warped fwiw
