Generation IV External Engine - Alternator wiring - 05 GTO harness with Vette alternator
MX6.0
02-09-2012, 10:15 PM
I'm using the CTS-V / G8 GT accessory kit on my 05 GTO LS2 harness for my swap. I have just about all the wiring figured out but I'm struggling to find some good info on this alternator.
Here's what I have:
http://i974.photobucket.com/albums/ae226/mkline321/P1010492-1.jpg
GTO Alternator from left to right:
1-gray
2-orange
Vette alternator from left to right:
1-red
2-gray
3-red
4-empty
I need to cut the GTO plug off of the harness and attach the new 4 pin plug. I just need to know exactly what wires are going to where and what their function is?
S10xGN
02-10-2012, 09:26 PM
...I need to cut the GTO plug off of the harness and attach the new 4 pin plug. I just need to know exactly what wires are going to where and what their function is?
Can't help you on the wires, but why not de-pin the connectors instead of cutting them? All it takes is a $4.00 Metripak tool...
Jontall
02-11-2012, 12:04 AM
http://ls1tech.com/forums/attachment.php?attachmentid=339654&stc=1&d=1328940010
Connector Part Information
• 7223-6224-40
• 2-Way F (GY)
Pin
Wire Color
Circuit No.
Function
A
WH
2
Battery Positive Voltage
B
BN
25
Charge Indicator Control/Charge Indicator Signal
http://ls1tech.com/forums/attachment.php?attachmentid=339655&stc=1&d=1328940225
• OEM: 12186684
• Service: 15306009
• 4-Way F Metri-Pack 150 Series (BK)
Pin
Wire Color
Circuit No.
Function
A
Not Used
B
OG
225
Generator Turn On Signal
C
GY
23
Generator Field Duty Cycle Signal
D
RD/WH
2540
Jontall
02-11-2012, 12:11 AM
The 04 GTO are internally regulated. 05-06 are a PCM controlled generator to help MPG. They are Mitsubishi alternators.
Sleeper S10
06-16-2013, 11:52 AM
• OEM: 12186684
• Service: 15306009
Pin
Wire Color
Circuit No.
Function
A
Not Used
B
OG
225
C
GY
23
D
RD/WH
2540
Can someone please tell me more of what Pin D does and where it would wire to on a C6 Corvette?
I just fisinshed a swap on my S10 and I`m hoping hooking this one last wire up will get rid of my battery light.
I was told to run a 6 inch cheater wire from Pin D to the alternator main output lug to the battery.
Other the that I have:
Pin A - Empty
Pin B - Brown wire to C2 15
Pin C - Gray wire to C2 52
Pin D - ?
(On a LS1 style computer)
Sorry to hijack and thanks for any help!
MX6.0
06-16-2013, 09:26 PM
Take a look at the pins on your alternator. On mine, even though there we're 3 wires on the pigtail, there were only 2 pins on the alternator (no actual pin connected to the "D" wire). Mine only used the center 2 pins that were labeled L and F.
Sleeper S10
06-17-2013, 05:51 AM
I have pins on B C D.
Nothing on A.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
