engine options
engine options
hey guys,
im looking to put together a 370-408 long block, i have 6500 to do it with.
it will be going into my 02 SS mated with a d1sc procharger with 10-15 psi. think that it can be done? im talking 6500 for long block not the procharger..
thanks.
thanks.
It looks like you can damn near purchase it built for that type of money.
http://www.texas-speed.com/p-655-tsp...ong-block.aspx
If you can do the assembly work yourself and have a good machine shop available then your budget should work fine.
You might want to contact a few of the vendors and get some quotes.
Good luck
Good luck
AES 390 is designed for boost - great choice. #2 would be a 370.
For 15 psi, I would look to aftermarket with thicker deck - you are at the ragged edge of stock style heads and any tune issues could get you in trouble. I'd say go L92 or LS3 over ported 317's if you can back down on boost desires - LS3 intakes are pretty cheap as well and flow better than most.
For 15 psi, better option would be the the F1A Procharger if you can stand the noise. Not a lot more to buy and will be better suited for higher hp application. You will need FMIC and should consider Aster mount to avoid belt slip problems.
Long block engine can probably be completed for the $6500 range with a GM casting for head. AFR, TFS or MAST heads build will raise price. Balance of your existing mods will match boosted engine pretty well.
where is this not forged bottom end talk the 390 is forged internals
6.0 Iron Engine block
Callies Compstar C-series crankshaft 3.825" stroke
Callies Compstar H beam connecting rods
CP Pistons 2618 forging -15cc D dish
NPR gas nitrided piston rings, napier 2nd ring
King HP bearings, durabond cam bearings
All parts are thoroughly cleaned before assembly
Crankshaft balanced and polished
Line honed main journal
Resurfaced cylinder deck
Torque plate honed bores
Assembled in our clean, dedicated, engine assembly room.
390ci shortblock package with the addition of
-Ported '317' GM castings, assembled with stainless valves and Patriot Gold dual springs
-ARP head studs/ ARP main studs
-GM MLS gaskets
-Comp Cam/LS7 lifters
-JP Performance double row timing chain
Heads are assembled, installed, camshaft degreed
with 10 psi? what you think.
-GM MLS gaskets
