4.8 cam swap wont start
Hold the pedal to the floor to clean it out. When the computer detects 100% throttle position during starting it cuts fuel to attempt to clear a flooded engine. See if it shows any signs of life then.
Ive done a ton of cam swaps and built a "few" ls motors and never had one not start.
Did it have any kind of tune put on it? Did you swap injectors?
I did a cam swap on my 4.8L using a 216/220 and it did the same. Once it started I had to just hold the throttle a bit so it would idle for a bit. After doing that a few times it idled fine on its own.
