Drag Racing Tech - lt1 m6 cross member for th350 swap?
starbucks
02-11-2012, 12:48 PM
Hi guys Im looking for a little help, I am in the process of getting some parts together for an 95 lt1 m6 to th350 swap together and I am having an issue finding a straight answer when it comes to cross members. I have a umi tunnel mount torque arm and was wondering if I could use the factory m6 cross member for the th350 swap and if some modification need to be done what are they is it possible to get some pictures?
Mighty Whitey
02-12-2012, 12:44 PM
IMO (and in my case) I found it easier to use and modify a stock automatic crossmember to work for the th350. The mounting location on the th350 is 2" further forward than on a 4L60e, and pretty close to the same "height"
Here's the haggard looking one I ran in my car for years:
http://i2.photobucket.com/albums/y35/indigoblue94/6ca78d62.jpg
http://i2.photobucket.com/albums/y35/indigoblue94/72f00166.jpg
http://i2.photobucket.com/albums/y35/indigoblue94/d01369b7.jpg
Hope this helps
ssvert99
02-13-2012, 04:16 PM
the a4/m6 crossmembers are completely different, and likewise from 93-97 and 98-02... so... there are 4 different ones.
MWC makes all the conversion crossmembers for both models and for all the different transmissions. available in aluminum, chromoly, and mild steel.
