jetblk84
02-11-2012, 05:37 PM
hey guys, new to this forum but im a member of many other forums. i have a 84 chevy c10 that i have been slowly restoring, i just got it running and the engine consists of: 355 shortblock flat top pistons, dart SHP alum heads 180cc runners 64cc chambers, comp thumpr cam and lifters, hardened comp pushrods stock length, edelbrock rpm air gap intake, msd hei complete dist, edelbrock 1406 carb, still have the manifolds on the truck but has true duals with flows, have a set of headers and an xpipe going on tomorrow... the truck recently got 16 mpg on the highway driving from indianapolis to michigan and back. it runs alright, makes good power but it seems very boggy off the line. also the truck has a mild 700r4 trans in it, with a stock torque converter. i know i probably should get a stall converter but it seems like its an engine bog and not an issue with stall.
i have checked plugs and were a little rich so i leaned the carb out a little, my confusion comes from the timing. right now it is advanced somewhere between 35-40 degrees just to run! if i get it down to 16 degrees (which is where my timing indicator stops) it wants to die and runs horrible. why would it have to be so advanced just to run?
please any info or suggestions will be greatly appreciated. i have been chasing this problem for about 2 weeks now. it has me stumped.
