Advice on tank for a 67 A body Conversion
Done a little skimming and cant seem to find a vendor or soild suggestion on which way to go for a FI tank for my conversion. My apologies if this has been covered. Don't really want to go to a fuel cell. Thanks in advance.
Tony
Tony
Check out the build below of this outstanding looking Buick. Might be of some help as long as you are talking GM A body and not Mopar.
https://ls1tech.com/forums/conversio...ld-thread.html
There are a few options based on which way you want to go.. Intank or external.
Intank...:
You can replace the tank with a Rick or Valley Stainless Steel tank with In tank pumps. You can also swap in a 94-96 B-Body Tank. ( I am using one in my 71 Chevelle). A Grand National tank is also a good swap.
You can convert your existing tank with a drop in pump unit like the Tanks Inc.
http://www.tanksinc.com/index.cfm/pa...=cat/cat61.htm
You can use a 4th or 5th Gen F-Body pump. Vetteworks has the ring for the 4th gen.
http://www.vetteworksonline.com/ls1_conversion_fuel.htm
There is a kit for the 5th gen pump. http://vaporworx.com/
www.retrofuel.com is starting to market low cost tanks with the 5th gen pump.
Some have used the Spectra tank, but many problems of starvation.
External..:
Or you can go external with many external pump (MSD, Aeromotive, etc), but recommend you sump the tank with a Competition Engineering kit.
http://www.competitionengineering.co...?CatCode=10070
BC
Intank...:
External..:
BC
Intank...:
External..:
BC
Intank...:
External..:
BC
