Carbureted LSX forum - Street/Strip LS Coupe
View Full Version : Street/Strip LS Coupe
LSmonster
02-12-2012, 12:33 PM
Not many build threads in this section so I thought I'd put this one in here.
This is a street strip project with a goal of mid 9's on pump gas, N/A and low 8's on the bottle. I plan on taking this car on one of the "Drag Week" events in the future.
1993 Mustang Coupe.
Wolf mini tubs
Moser 9" housing with back brace
Strange Ultra 3rd member
Strange spool, 40 spline axles, gun drilled with 5/8" studs
Strange disc brakes all the way around.
Race Craft K-member
Race Craft 2" dropped spindles
Race Craft Caster/Camber plates
Race Craft 12" A-arms
Race Craft upper and lower rear control arms
Race Craft manual steering rack and bump steer kit
Strange front and rear coil over shocks
F-R-E anti-roll bar system
Hughes Performance PG with SFI case and trans brake
Hughes Performance flex plate.
Neal Chance 9" nitrous converter
Complete new tin work for the floor
Kaenen 4" cowel hood
Complete new carpet, throughout.
Ron Davis radiator with electric water pump.
F-R-E front bumper support with tranny cooler
F-R-E front travel limiters
Kirkey seats and covers
Simpson 5-point seat belts.
Custom fit Shroud window net
10 gallon fuel cell with sending unit.
F-R-E custom oil containment pan
Smoothed firewall
F-R-E motor plate and mid plate
F-R-E 25.2/25.3 SFI roll cage.
Engine: F-R-E 427 (pump gas)
ERL Super Deck 1 six bolt block.
Callies Magnum XL crank
Carrillo 6.125" rod with CARR rod bolts
Wiseco pistons with HD pins
Mast Motorsports large bore square port heads
Mast Motorsports intake manifold
Pro Systems dominator carb
Wilson Pro Flow fogger kit.
Custom F-R-E cam
Jesel Rockers
A-R-E dry sump oil system
Jesel Belt drive cam
Jesel Belt drive distributer
ATI damper
ARP head and main studs
F-R-E billet valve covers
F-R-E billet valley cover
F-R-E billet rear block cover
F-R-E billet tentioner
F-R-E billet idler and tentioner pulley
Complete Magna Fuel system
MSD 7AL-3 ignition
MSD HVC II coil
http://i581.photobucket.com/albums/ss259/Dragzilla/Turbo%20LS%20Coupe/001-5.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/006.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/002-2.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/003-4.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/001-4.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/014.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/004-2.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/020.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/002-1.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/003-3.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/013.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/005.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/001-6.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/001-7.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/002-4.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/003-6.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/004-3.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/005-3.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/006-3.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/015.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/018.jpg
Doug G
02-12-2012, 01:41 PM
No suggestions.... but nice monkeybar work :nod:
1quickguido
02-14-2012, 08:13 PM
Very nice fab work!
S10xGN
02-15-2012, 07:24 PM
...This is a street strip project with a goal of mid 9's on pump gas, N/A and low 8's on the bottle. I plan on taking this car on one of the "Drag Week" events in the future.
It ought to get there easily!
What's up with all the mill work in the lifter valley? Will the lifters come out w/o removing the heads with that "mod"?
johnyrrr
02-16-2012, 07:15 AM
Dang overachievors:D
LSmonster
02-16-2012, 10:50 AM
That's so you can get to the head bolts that go from the bottom of the head. You can get to the lifters through there too and ERL make a hold down that mounts to the center of the valley area for lifter guides... It's pretty slick.
S10xGN
02-16-2012, 07:34 PM
Yeah, I totally missed the 6-bolt option. And after another closer look, I see how the lifters can be removed.
Thanks!
yea i bet
02-21-2012, 12:49 AM
Did you make those motor plates yourself or did you buy them?
Im looking to get/make some for my fox.
http://i130.photobucket.com/albums/p246/runem99/403344_10150455165352831_654917830_8875948_6323388 38_n.jpg
LSmonster
02-21-2012, 09:20 AM
I make them.
zeosick
02-21-2012, 11:01 AM
You got a good start on a sweet ride.
LSmonster
02-23-2012, 08:54 PM
Floor is going in. It also has that new chrome molly U-joint covered required by NHRA for 2012. Not sure I needed it because I have steel floors and they will be fully welded in... but I'm there now so what the hell. It will improve resale value I guess it's a good thing, needed or not.
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/001-8.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/002-5.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/003-7.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/005-4.jpg
LSmonster
03-04-2012, 09:06 PM
The floor, seat tabs and belt tabs are finished. All the tabs are welded to the floor bars. The seat brackets set flat on the floor and bolt to the tabs underneath the tin work.
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/010.jpg
Doug G
03-05-2012, 04:24 AM
Very nice work :cheers:
ERL Performance
03-05-2012, 08:41 AM
Clay always does nice work! The man is a perfectionist. Trust me, I know!!!!! :)
Great job Clay. Can't wait to see this thing scream down the track.
GC99TA
03-05-2012, 05:38 PM
The car is looking great Clay. I just realized who's build this was....LOL. I can also vouch for the excellent working coming out of F-R-E!
LSmonster
03-24-2012, 01:36 PM
Here's a shot under the car. I kicked the rear DS hoop out just a little on one side so I could get the shaft out without having to remove the rear shocks.
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/006-5.jpg
JRracing
03-28-2012, 10:20 PM
Another sweet build man.
Jared_Williamson
04-03-2012, 06:15 PM
That is very nice work. I have done a handful of cages in fox body mustangs, mostly just the wolfe kits. The main hoop forward is the cookie cutter part, I always like seeing what people do from the main hoop back. Yours came out very nice, I like the ideas.
LSmonster
04-03-2012, 09:01 PM
Thanks, guys! And there are more bars in there now... I'll try to get some pics loaded up soon.
The only thing left is the tin work in the back trunk area, mounting the fuel cell and finishing up the anti-roll bar setup.
LSmonster
05-19-2012, 04:05 PM
Tin work in the trunk is pretty much done and the anti-roll bar setup is finished. <(All but the hardware)
All the bars are in back are finished too. Now the only tin work left is the front panels by the shock towers. Then I'll fill and smooth the engine bay and take it to get it painted. (I don't do paint)
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/003-9.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/004-6.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/005-6.jpg
westTEX26
05-19-2012, 07:03 PM
Nice!! Drag Week would be a real test
LSmonster
06-09-2012, 12:03 AM
It's getting closer. All the holes are filled in the engine bay and the fender well panels and bumper support and trans cooler mount is installed. It's pretty much ready for paint at this point. But I want to finish the rear bulkhead in the trunk area first then it can go have the carpet installed right after I get the engine bay repainted. After all that is done, I can start on the engine.
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/001-10.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/003-10.jpg
LSmonster
07-19-2012, 08:59 PM
Started working on the engine and mocking up a few things. This should be finished in a couple of weeks, time allowing.
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/002-7.jpg
daniel044
07-19-2012, 09:04 PM
Sweet build.
90lscamaro
07-24-2012, 08:22 PM
Good lookin build.
LSmonster
08-03-2012, 08:08 PM
Heads are done and ready to install. These are Mast Motorsports 285's with all the goodies. I've used a bunch of these heads going back to the ETP days... Very good product so I'm sure these will work great! Thank you Mast Motorsport for a killer set of heads!!!
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/002-9.jpg
LSmonster
08-24-2012, 08:34 PM
Engine bay is painted. Next up is paint the cage and install the carpet.
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/P1010126.jpg
JRracing
08-24-2012, 11:50 PM
Sweet. When do you want me to bring mine over lol.
ZONES89RS
08-25-2012, 12:32 AM
Do not understand distributor.
LSmonster
08-25-2012, 12:22 PM
Bring it on over. :nod:
LSmonster
08-25-2012, 12:27 PM
What part? What it is or how it works?
It's a Jesel Belt drive distributor that is driven off a pulley on the cam. As it rotates it spins the rotor button and the plug wires are installed in the engine firing order. There will be a crank trigger on the harmonic balancer that will tell it when to fire the coil. There are no other parts inside the distributor.
gsxkid
08-25-2012, 02:37 PM
what advantage would a distributor offer over coil packs?
wildcamaro
08-25-2012, 02:39 PM
Holy shit that roll cage and subframe bracing is crazy it prob weighs more than the body...what is it rated to? 6s in the quarter lol! Nice build man
LSmonster
08-25-2012, 02:51 PM
No timing chain, less harmonics and very accurate timing. And you can use a nasty MSD HVC II coil. Plus it's plug and play with just about any MDS product they make. This is a nitrous car so I'm using a MSD 7AL3 box with all the nitrous retards, ect... Very clean and user friendly.
LSmonster
08-25-2012, 02:54 PM
Thanks! It's all Chromoly tubing so it's not as heavey as you would think. And yes, it's a 25.2 cert cage (6.0 seconds 1/4 mile)
SS10Tech
08-25-2012, 09:16 PM
Subscribed.
I actually have designed a very similar build - down to the chassis, SFI qualifications, street/strip application, and ET goals. Only difference is the transmission and motor in getting there. 540 BBC through a GF5R on EFI instead of carb. NC emissions regulations hold a few limits on the street part.
What lifters are you going with? and i am also stealing your poly trans mount adaptation - that is a slick setup. You dont need to poly-mount the mid-plate as well do you? What are your plans for front to back torsional forces or does the trans mount take care of it for you all at the same time?
Also, do you mind PM'ing the book you have for the SFI requirements or where to get the annually updated issues?
Thanks ahead of time!
streetknight2
08-26-2012, 06:26 AM
How much does the distributor set up set one back? Interested
ZONES89RS
08-26-2012, 08:19 AM
I just figure there would be a better ignition setup that would avoid a distributor in general. Perhaps maintain individual could setup. Seen built setups above 1000 HP using stock coils, so it makes me scratch my head.
LSmonster
08-26-2012, 04:22 PM
For this engine a COP setup would work fine. But I had this setup on my last carb/nitrous combo and it works flawless so I'm sticking with it. On my other Coupe which is a Turbo car, I tried the COP setup and had nothing but problems with it. So I switched it to the setup and now it too works falsely.
There comes a point in which the COP setup has it's limits. A bunch of folks start off with the COP system but eventfully they get away from if for one reason of another... There are a bunch of build threads on this site that have address the pros/cons of the COP ignition.
LSmonster
08-26-2012, 04:35 PM
The belt drive cam setup is about $1,500.00 and the Jesel belt drive distributor IS ABOUT $650.00
LSmonster
08-26-2012, 04:44 PM
Subscribed.
Cool! Do you have a build thread on your project? I love watching these things come together.
As for lifters, I'll be using the ISKY "Red Zone" lifters with the plus .300" body with offset cups on the intake to allow me to run larger OD pushrods.
The front motor plate and the mid plate are bolted, rigged. I have a poly mount on the trans cross member. As for the lateral movement (banjo effect of using motor plates) I'll be installing a arm with heim joints at each end from the front of the heads to the forward section of the frame rails.
PM me any time if you have any questions... I'll help if I can.
SS10Tech
08-26-2012, 06:57 PM
No sir, no build thread - storage concerns and time availability - something i simply do not have at this time. Instead i am in the process of funding the top end of motor, and this time next year the bottom end and getting a dyno result before storage for the chassis to be completed.
Any reason to not convert to a mustang II front end suspension setup? Ive got weight concerns with this particular build as the block is iron and may need to move the motor back - anything you might have to say on this i am all ears.
Cool that out of all of the combinations that exist both of us chose identical ET goals on such a similar platform :cool:
LSmonster
08-26-2012, 07:35 PM
That is a question I can not answer. I've never used any Mustang II stuff so it would be less than a guess if you would have any issues. I know a lot of folks graft that front end onto almost everything but it's usually just "Hot Rod" stuff, not like what you are doing...
JOER
09-04-2012, 11:10 PM
Nice build!!!!!! I LIKE IT!!!:cool:
LSmonster
03-10-2013, 06:50 PM
It's been a while so I thought I'd update this build.
The engine is in and I'm plumbing it now and the exhaust is in too. Once the plumbing is finished I'll start wiring and then install the carpet, seats, belts and all the little craps that eats you alive in time and money. :D
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/004_zpsa6de328f.jpg
ZONES89RS
03-11-2013, 04:57 AM
Loos like a race car to me!
LSmonster
03-11-2013, 10:14 AM
I have NHRA to thank for that. If I plan on running low 8's at the track you gotta add all that cage work. But it will run on pump gas, have full exhaust and full interior and have tags and insurance so it will get plenty of street time. Alot of those miles will hopefully be during Drag Week if all goes well.
ZONES89RS
03-11-2013, 02:06 PM
I know, it is a thing us street car guys say to give each other crap.
LSmonster
04-10-2013, 10:15 PM
Well it’s running and the cage has been certified. It sounds great and it's very zippy. :)
It’s at the carpet shop now getting insulation and carpet installed throughout, then it will come back to me and I'll finish it up. (Hang the nose, fenders, hood, dash, doors, windows, seats, misc. wiring, yada, yada)... Can’t wait to take it for a spin.
:drive:
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/001-1_zps8b687638.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/005_zps672caf6e.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/003-1_zps17518d2e.jpg
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/001-13_zpsba2889ab.jpg
Nicksilverado
04-11-2013, 06:01 PM
Serious car!
LSmonster
04-25-2013, 08:41 PM
Getting closer. Big stuff left to do is put the glass back in it, install a window net and order a drive shaft. I still have some wiring a some dash work to do but I hope I'll be finished up with that stuff this weekend.
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/016-1_zps827b4bf2.jpg (http://s581.photobucket.com/user/Dragzilla/media/Black%20Coupe/016-1_zps827b4bf2.jpg.html)
jaywill
04-25-2013, 09:15 PM
Damn !!!
JRracing
04-27-2013, 09:51 PM
Man it looks great. Nice job. again.
The blue car looks lonely. Surprised you didn't sale it.
LSmonster
04-27-2013, 11:39 PM
Thanks. And the blue Coupe is not going anywhere for a while. It needs a new block (Dart LS Next) that I have on order. Can't wait to get than one back on the track and turn it up! :nod:
OnlyACamaroCanbeAZ28
04-28-2013, 04:04 AM
loving that little LSX sticker on the cowl:nod:
onefast84
04-28-2013, 08:07 AM
Sweet car! Not a bad way to spend extra pocket change! lol!
JRracing
04-29-2013, 11:55 PM
Put the wife in the blue car lol.
LSmonster
05-18-2013, 03:13 PM
Black car, Maybe... Blue car, no effin' way! :)
Here is a pic of both. Black car is done and the blue car is still waiting on a new block.
http://i581.photobucket.com/albums/ss259/Dragzilla/Black%20Coupe/001-13_zpsbf563736.jpg (http://s581.photobucket.com/user/Dragzilla/media/Black%20Coupe/001-13_zpsbf563736.jpg.html)
