Dyno Guesses & Bench Racing Forum - What to expect on track?
View Full Version : What to expect on track?
2000NemeSS
02-12-2012, 12:53 PM
Ive yet to take my 2000 M6 to the track, will be going to the track March 4th, lookin forward to gettin my time slip for the first time in this car. My mods are in my signature, any ideas on what I should turn, its on regular street tires, good tread hankook, what would the car be capable of realisitically? Ive yet to see a real time of what people are turning out in a similar setup, I live in mustang country and it sucks.
wannabfast
02-12-2012, 01:15 PM
Lots of other stuff to consider here. But i couldnt see why you wouldnt be in the 12s for sure. In my 99 on 245 street tires i had a 2.0 60 i ran a 13.3. my mods were cai, tb spacer, and thats it. so i would say 12s for sure depending on how you drive and if you hook
2000NemeSS
02-12-2012, 01:18 PM
cool, i am hoping for 12s but i dont want to go and have a huge let down when i run a mid 13 or something. I havent had an issue with hookin up, Im use to driving foxbodies with crazy gears and what not, this car is remarkably easy to drive
6SSPEED
02-12-2012, 01:41 PM
2.0 60ft.
13.1 1/4 mile
MikeWS6
I doubt you will run 12's the first time out. Its possible though.
wildcamaro
02-12-2012, 02:46 PM
I can't see your mods since I'm using iPhone...what u got?
baxsom
02-12-2012, 02:53 PM
my guess is low 13s with a 2.3 60' time. First time out people tend to really mess up the launch and spin the tires. if you have open clear highway where you can practice launches your first time at the actual track would be better. remember until you roll forward the time doesnt actually start. your reaction time might show sucking but your 1/4 mile will benefit. it is natural the first time out to get so hyped up when the light goes green to just dump the clutch and punch it.
VandykeT/A
02-12-2012, 03:25 PM
My guess would be low to mid 13s with street tires and the 342s. My 2000 Z28 M6 went 12.8 at 106 with the only mods being a lid, headers and ory, and a 410 gear on a set of et streets. Speedometer was calibrated with a diablo tuner. I cut 2.0 60s on street tires and ran 13.1.This was at Bristol, TN with all stock suspension.
2000NemeSS
02-12-2012, 03:43 PM
its not my first time at the track, just with this car, everywhere i go typically i drive aggressively, since doing the suspension mods I havent had an issue with wheel spin, some at high rpms but at the track i wont have the same problem as gravel roads. If my tires are cold, terrible traction problems, once warm they actually stick well, im surprised by the hankooks. Im more or less what should I expect from the car, not me. I know some runs i may do horrible, some may do well. ive seen bone stock with slicks do high 12s, i hope with my mods im doing the same
2000NemeSS
02-12-2012, 03:49 PM
my mods are
SLP Flopack
smooth bellow
LS6 Lingenfelter intake with egr delete and air delete
rear 02 delete
BBK long tubes with off road Y
MGW short throw
BMR tube torque arm
Spohn Lower control arms
Tune by EFI Livewire system by pro
k_garretson23
02-12-2012, 04:37 PM
There is a lot to consider, I have similar mods and my best is 13.3 with a 2.0 60foot.
gs462
02-12-2012, 05:33 PM
I agree here I think low 13s strictly because of the street tires they will NOT hook, a better indication of how much power the car is making will be your MPH, MPH tells horsepower. ET can change substantially due to traction. I will guess you trap around 108 -109 mph tho.
2000NemeSS
02-12-2012, 07:54 PM
Im good with 13s, Im too scared of throwing slicks on a 10 bolt, its my DD so the last thing I need is to blow that sucker! :bang:
TransAmcoupe98
02-12-2012, 08:03 PM
You'll be looking good to get a 2.0 short time your first pass in the car. Depends on the DA that night also. But I'll guess a 2.1x short time and a 13.0 @ 109 ish
TransAmcoupe98
02-12-2012, 08:05 PM
Again, your car is capable of going faster, but you just don't have the seat time yet bro. You'll get there. Make 7 or 8 passes that night. Maybe after a few full out runs, just work on your short times and shifting instead of beating the snot out of it.
stangtrader
02-12-2012, 08:10 PM
Hard to say. The key with my car on stock size street tires is to launch at 4k rpms slipping the clutch a little bit to keep wheel spin under control and not brake the ten bolt. My best 60' is 1.89 on street tires at 12.75@110.98 MPH with full Bolton's granted I have a stock lq4 but if I would have launched the same with the ls1 I would have ran 12s easy. With the ls1 leaving off idle I went 13.17@ 108.
gs462
02-12-2012, 08:21 PM
As a comparison years ago when my turbo regal was pretty stock it went 12.70@ 109 with a 2.0 60 ft. on street tires. I borrowed a set of slicks the same day and went 12.20@ 109 with a 1.7x 60 ft... So 109 mph is low 12s with good traction.
gs462
02-12-2012, 08:40 PM
I completely understand, Im building a 550 ish HP LQ4 for my WS6, which still has the stock trans and rear which I know will be living on borrowed time.
2000NemeSS
02-12-2012, 08:42 PM
Loving all the posts, it looks pretty safe to say a pretty low 13, my track opens up for test and tune on March 4th, I will have to post up my time slips when I do my runs.
2000NemeSS
02-12-2012, 08:48 PM
Oh also, does anyone know the curb weight of our F-Bodies? I dont have some stupid sub box in my car or anything. I was just curious what they weigh with all the fluids
VandykeT/A
02-12-2012, 09:59 PM
I believe 3400-3600 I believe. The title to my 2000 SS says 3439 empty. M6 leather, t-top car.
2000NemeSS
03-05-2012, 06:23 AM
So, I went to the track this weekend like I said I was going to. For all those who care here is my best time.
13.300 @ 108.78mph
time slip
r/t .030
60ft 2.212
330ft 5.836
1/8 8.751 mph 85.53
1000ft 11.216
1/4 13.300
mph 108.78
Not too bad I suppose, My signature isnt exactly right, i planned to have those mods on by this weekend but my intake wont fit on my car, the snout is incorrect. so my corrected mods are..... BBK LTs and SLP Lid and K&N filter... Not bad I suppose on street tires (not even nittos, crappy Hankook Ventus)
I NEED SLICKS!!!!!!!!! :hump:
M1tch
04-16-2012, 04:37 PM
Hey man i Have a really similar setup and I'm running again this weekend. Have you had any clutch problems going into 3rd? Mine has been doing the classic pedal sink to the floor. If you have I was wondering if you had any suggestions on how to shift when that happens
BTW Try launching at 2500 RPMS and slip the clutch. If you can bring your 60' down to a 2.0 you should see a 12.85-12.95. I was running 13.100 a@ 105.9 with a 1.9 60' in my 92 Camaro with a vortec 350 so that just shows how much the launch matters
M1tch
04-16-2012, 04:57 PM
Did you have your car tuned yet?
