2002 lq4
2002 lq4
I have a 2002 lq4 with 114k miles should i do bearings and rod bolts I'm going to do heads and cams performance wise what should i do other than heads and cam. oh ya ill also do a oil pump. should the cam bearings be fine? and what bolts and gaskets can be reused?
yeah i was thinking about doing rings but I'm not sure on them either. The problem is is that I'm not sure how to check the clearances for everything so i was thinking about taking it to a machine shop and have them clean it do the bearings and rings but i don't know how much that would be.
