Drag Racing Tech - Turbo 400 LT1 Gear Ratio for 1/8 or 1/4 Mile or Compromise for Both
StraightTimeStirrups
02-12-2012, 03:36 PM
Which gear ratio would you choose for either an 1/8 or 1/4 Mile set up? If you had to choose a compromise to run at both distances which ratio would you choose?
Joe
buzz12586
02-13-2012, 08:41 AM
How much power does it make? What tire? Weight?
02-13-2012, 09:16 AM
About 350HP for now. The car is pretty much stock weight for now. It will eventually get to 500-550HP and go on a diet.
Joe
Wicked94Z
02-17-2012, 12:12 AM
I run a 4.71 for the 1/8, it was originally for N/A 1/4 mile stuff with the 6 speed. Now it works for nitrous 1/8 mile runs. Might still be able to squeek out the 1/4, spinning the motor 600 rpm higher now.
Big Al
02-17-2012, 12:48 AM
Mine has a TH-400 with 4.30's and a 28" tire. But it all depends on how fast you're going to run and what RPM's you can pull. I try to keep mine under 6,500 and my engine is stock with a cam and headers. It only runs 112 MPH.
Al 95 Z28
02-17-2012, 01:13 AM
Al 95 Z28
What are your times that you run?
My plans are a mess now. They shut down the track down (Irwindale) that I was going to run the car at so I am still up in the air of what to do for a gear now as I am not sure if I will be building an 1/8, 1/4 or combo car now!
Joe
Wicked94Z
02-17-2012, 03:16 AM
irwindale is shut down?? I moved from Upland about a year ago, born and raised hanging out at irwindale. what's the deal with that? pic in my sig is at irwindale, avatar is at fontucky.
i have a continental converter, a 5600 8" converter that hits super hard and runs really efficient. you'll be pleased with yours!
Big Al
02-17-2012, 10:17 AM
Joe
That run was 12.151. But my engine is dead. The tune is far off and the knock sensor is retarding the hell out of the timing. If I had 50 more horsepower I'd run out of gear in the 1/4 mile. My 60's are also way off as I can't hold the car with the brakes. So I need to do some more work, like add a line lock and wire up the trannie brake. It's a work in progress:) Right now I'm moving the seat back so I can get in and out. It's hell to fight an old body.
Al 95 Z28
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
