Pontiac G8 2008-2010 - Cam or Torque Converter/Camaro Diff? Which one??
rlwjr1
02-12-2012, 05:18 PM
I'm leaning more toward the converter/gear swap. Correct me if I'm wrong but I'm estimating a cam swap will be about $1500. I think a gear/torque converter will cost close to the same. In terms of 1/4 mile performance I also think the gear/converter is the best bang for the buck.
Thoughts/opinions????
SREETRACEGUY
02-12-2012, 05:27 PM
these cars have very good heads so depending on the cam you pick. the cam could give you faster times. however the stall will def give a lot of performance. I suggest getting the DOD stuff out and doing the cam first before they fail and possibly break other stuff. thats my opinion so best luck to you but ether route will be fun
Tainted
02-12-2012, 05:40 PM
converter.
gives a huge increase in performance, and sets you up later for a better cam!
Gordon0652
02-12-2012, 08:59 PM
converter.
Exactly.
rlwjr1
02-13-2012, 03:43 PM
I need to drive a 6A Camaro. I really feel in the distant future there will be some sort of F.I. The 3.27 gears would be nice for that or maybe a large cube stroker. Thanks for the help...
Tainted
02-13-2012, 03:44 PM
Too much gear and you wont have traction especially supercharged
94 guy
02-15-2012, 01:37 PM
i have 2 complete 2010 camaro rearends. 1 has 3.27 the other is the M6 3.45. i'm looking to get rid of them. pm me if your interested.
2QUIK4U
02-15-2012, 04:14 PM
I would do the converter and gears first. If you go with a big cam you will need them anyway. I put a fairly large cam in my G8 and it pushed the brakes so bad I had to get a converter.
Tainted
02-15-2012, 05:01 PM
How much for the 3.27 and is it LSD?
94 guy
02-15-2012, 07:37 PM
pm sent. i think all ss/rs camaro's are lsd? both of these came out of V8 cars 1 is a L99 the other is a M6.
Tainted
02-15-2012, 07:44 PM
As long as its not a V6 car then it will have LSD.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
