Generation III External Engine - ls1 vs ls6 vs weiand vs BBk
HottLS1Z
02-13-2012, 10:50 AM
So I know I see the intake question a lot, and I was recently researching a couple myself lately, but solid dyno comparisons seem hard to come by. Well while searching I ended up on another forum and found a great dyno comparison for the intakes mentoned in the title. Figured id share it in here for anyone else looking for info. Scroll down to post 27 for the dyno results.
http://www.ls1gto.com/forums/showthread.php?t=347366
wildcamaro
02-13-2012, 11:17 AM
I've never seen the ls2 beat an ls6 Intake...interesting graphs...good post
HottLS1Z
02-13-2012, 12:00 PM
It didn't here either, ls6 489hp@5900rpm compared to the ls2 485hp@6000rpm. I thought the ls2 would have been better myself. I just bought a bbk myself, glad I went with it after seeing this.
MikeWS6
02-13-2012, 12:31 PM
I wouldnt read too much into this. Anyone of those intakes could dyno higher than the other on a different day (Expect the LS1 intake)
HottLS1Z
02-13-2012, 12:54 PM
Not really, even a slight change in temp is not going to make that big of difference. Also looks like this was an engine dyno, which usually means same dyno, same location, same temps (probably indoors climate controlled) and seeing as there only manifold dynos I bet there all done in the same day. Easy swap. The resutls can't be argued.
MikeWS6
02-13-2012, 10:16 PM
No really, even a slight change in temp is not going to make tht big of difference. Also looks like this was an engine dyno, which usually means same dyno, same location, same temps (probably indoors climate controlled) and seeing as there only manifold dynos I bet there all done in the same day. Easy swap. The resutls can't be argued.
You just have to remember that alot of the guys who compare these graphs are trying to sell something. I have seen bbks dyno higher than ls6's and the other way around. Thats what I was trying to say.
HottLS1Z
02-13-2012, 11:19 PM
Idk man, I have been doing a LOT of research on the 3 aluminum ones the PP Typhoon, Weiand and BBK and never once have I seen anything with the LS6 doing better then the BBK. The Weiand yes I have seen mixed results but that BBK seems to be the best of the 3 from everything ive seen. I decided to pick one up. When I get it on the car I will post up if I feel any kind of difference over my LS6 with ported stock TB. Can you post up a link of something showing what you mentioned?
99 Blue Bird
02-14-2012, 10:14 AM
i wanted a BBK manifold. but i talked to some of my local tuners and they all said they were garbage. all are very reputable tuners as well. so i just left it alone. between all of the cars they have tuned they obviously have a reason for not liking them. so ill trust thier opinions especially when they are not trying to sell anything.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
