Sponsored by: DashLynx
Tough Brush-On Paint
Old 02-15-2012, 01:19 PM
CamaroManLS1's Avatar
Default Tough Brush-On Paint
Hey guys, so I'm getting ready to do my spring/shock/rotor swap this weekend. My plan is paint black all the old suspension hardware and miscellaneous things in the wheel wells. Chances are everything has surface rust that I'll have to grind off. I want to use a brush on paint thats rust resistant and really tough. I want to use a brush because it will be a lot easier to paint what I want rather than just spraying. So what would be a good tough brush on paint to use?
Old 02-15-2012, 06:39 PM
14k
14k's Avatar
Isn't there some pos-15 or something along those lines?
Old 02-15-2012, 06:41 PM
14k
14k's Avatar
Por-15**
Old 02-16-2012, 02:16 PM
silversrtman's Avatar
POR15 is awesome...super strong.
Old 02-16-2012, 02:43 PM
lees02WS6's Avatar
Make sure you spend some time prepping. I've found that POR-15 will flake if the surface underneath isn't prepped. POR provides marine clean and metal ready. Follow the directions, and it should work out well. You may also want to top coat it with some hard nose paint, as POR-15 can fade.
Old 02-16-2012, 02:57 PM
14k
14k's Avatar
What is hard nose paint?
Old 02-16-2012, 05:36 PM
Unertl42's Avatar
I did mine with Rustoleum Hammertone Black rattle cans, and then used caliper clear coat on it. It turned out good, you just have to spend some time cleaning the parts. I didn't get the surface rust off, I just used a brass bristle brush with some simple green, hosed it off, and used some acetone to make sure there was no grease/dirt on the parts
Old 02-16-2012, 05:39 PM
Unertl42's Avatar
Old 02-16-2012, 05:58 PM
Raleigh TA's Avatar
hmm, inspiring..
Old 02-16-2012, 08:32 PM
lees02WS6's Avatar
It's a two step paint that has a hardner. POR sells it. You can use it over top por-15, and it should be super strong.
Old 02-16-2012, 09:17 PM
lees02WS6's Avatar
Originally Posted by cobrakiller1989
i alwasy hear about por 15 where do you buy that?
I get it straight from their website. I also have used Rust Bullet Automotive Paint, which is silver.
Old 02-16-2012, 09:29 PM
The Mighty Texan's Avatar
I need to get around to doing this too..
Old 02-17-2012, 12:27 AM
14k
14k's Avatar
im thinking about doing this when i replace my spindle sometime soon. i need to get off my ***.
Quick Reply: Tough Brush-On Paint
