3" down pipe with stock k-member and mounts?
I have a stock k-member and stock mounts. I'm looking to run my 3" down pipe to a conventional exhaust - want to avoid running a dump or out the fender. Am I better off on the driver side or passenger side - Driver side is real tight with power steering, and the passenger side has the starter and the oil level sensor. Does anyone have any pictures of this done?
If Modular Turbo or CRB Performance sells the drivers side motor mount that comes with their $799 kit separately, you should check it out. Using the stock k-member with that motor mount, there's a ton of room on the passenger side. Definitely enough to run a 3.5" down pipe through there.
